Originally Posted by old red
what does " PR" mean anyways? my ride is american specs, same as everyone else
oh, sorry, I was referring to Cmry Racing because he's in Puerto Rico (
PR)
But what I commented on still stands for pretty much everybody who says that they've gone faster on their gen4s- your speedo is off.
In regards to cutting the wire most likely the speed sensor...your car will go into limp mode and then you won't even have the power to go beyond the speed limiter anymore due to air resistance
megamac brings up a good point though- depending on how toyota designed the actual fuel cut-off, and presuming that it really is JUST fuel cut off and nothing else, a piggy back unit such as an emanage ultimate would probably be able to get past the fuel limiter....not too sure about less functional piggybacks such as the emanage blue though, since they have problems fighting our ecus even during regular driving.
an SAFC will not work for sure, as all it does is alter the MAF settings.
I think gabe tried using an apexi revspeed meter in the past...not sure if he actually ended up using it, or if it worked at all. I'm not too familiar with how the revspeed meter works. to the best of my knowledge, the speed limiter cut that is programmable on the RSM can only set a NEW speed limiter, not remove a pre-programmed one on the ecu.
Somebody should try it with the emanage ultimate and let us know how it goes
