I4 gen3 died on hard brake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2008, 09:38 PM   #1 (permalink)
Engineer, tinkerer
View arlo's Photo Gallery
3rd Generation I4 gen3 died on hard brake
My girlfriend was driving my '93 I4 (I had been drinkin') when she slammed the brakes at a redlight. It was a pretty hard braking, but not ridiculously rough. Nonetheless a few seconds later I realized the engine had died. I started it back up (she had no idea what was going on) with no engine hesitation or problems.
This was the only time it died on me. I don't have ABS.
Was this some kind of safety feature or is it a problem?
arlo is offline   Reply With Quote
Old 09-24-2008, 12:16 AM   #2 (permalink)
just a nobody
Maybe it is just idling too low and the sudden stop cause it to choke itself out. I am not aware of a safety feature that would stall the engine.
N.E.O.
Old 09-24-2008, 09:19 AM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If she was running at a high RPM and suddenly dropped to a low RPM it may have been a glitch with the EGR, IAC, the air volume monitor (don't know if you have a 3SFE or 5SFE) or even a dirty throttle body.
Since it took a traumatic event to cause it you may have had a lucky glimpse into the future. You have an opportunity to track this down somewhat at your leisure. It will probably run fine during normal operation for a while longer.
Kep
Old 09-24-2008, 11:54 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
clean your throttlebody- or, especially, your IAC and it shouldn't happen again
HaHa
Old 09-24-2008, 12:02 PM   #5 (permalink)
just a nobody
I knew I had forgot something when I said idle too low.
N.E.O.
Old 09-24-2008, 01:45 PM   #6 (permalink)
Engineer, tinkerer
hmm, interesting. I was actually planning to clean the throttle body after seeing how easy the tutorials here show it. Is there a certain type of cleaner I should use?
Old 09-24-2008, 02:12 PM   #7 (permalink)
shajbot's Avatar
View shajbot's Photo Gallery
Anything that is o2 sensor and fuel injectors safe! :thumb:
shajbot is offline   Reply With Quote
Old 09-24-2008, 07:02 PM   #8 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
Exactlly what I was thinking too. Have the problem myself although it usually doesn't cut out.
cykaaro is offline   Reply With Quote
