Cig Lighter Alternative - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2008, 02:50 PM   #1 (permalink)
Restoring a '92 Camry
cmitchell5254's Avatar
View cmitchell5254's Photo Gallery
3rd Generation Cig Lighter Alternative
I have some small accent lights I would like to rig up underneath the dash on the driver and passenger side. They're just cheap little lights, so they have a cig lighter plug-in. Naturally, I don't want to have to plug these in every time to use them directly into my exposed cig lighter....can someone recommend an alternative method of controlling these that wouldn't be too exposed?
My plan at the moment is to just run another cig lighter mounter underneath the dash that can be easily plugged in. I guess I could go to the trouble to rig up a switch or button, but I really just don't want to invest that much effort into this small detail.
cmitchell5254 is offline   Reply With Quote
Old 09-24-2008, 04:00 PM   #2 (permalink)
Gameroom cash: $303255
You could also hardwire them up to any ignition switched 12 volt source. That way they will come on whenever you turn the car on. Just be sure to use an inline fuse if you do this. There is probably a fuse built in to the lighter plug. You can take that apart to see what ampereage fuse you need to install inline.
Mike
Old 09-24-2008, 09:11 PM   #3 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
i agreed with Mike.. i would too add a toggle switch or a switch of your choice so you can turn it on and off as you like..
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 09-24-2008, 09:49 PM   #4 (permalink)
blitzer_26's Avatar
View blitzer_26's Photo Gallery
i did the exact same thing in my old car... blue light under all the feet, inc. the rear
Solution:
i just cut the lighter bit off,
attached as fuse to the positive (safety first) as the lighter bit has a fuse inside, cutting this off means you have no fuse...
hardwired them to the parker lights rather than the battery (safer/cleaner)
installed a switch this way you can have the option of on or off but they will only come on if the healights are on (when else would you need them but when its dark)
the only thing is you have to run the wire through the firewall (very easy)
you can alo use relays and such...but that require a little electronics knowlege
also mine got kicked/broken many-a-time, i recomend some sort of protection, clear PVC pipe or a lightweight grille....this will also help fixing them to the dash
hide all the wiring and it will come up nice...
keep us posted with pics etc...
just finished wiring my fog lights, the electronic cuircut should be the same
*R.I.P* '94 CSI CAMRY 2.2L 4CLY
blitzer_26 is offline   Reply With Quote
Old 09-24-2008, 10:00 PM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Personally, I would get one of those add-a-circuit taps and put it in the fuse box inside on the cig lighter circuit. Then I would wire the lights to that.
Another option would be to add T-taps to the back of the cig lighter and then wire the lights to that.
2007 Camry 2.4L 5M
Old 09-25-2008, 04:02 PM   #6 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
I would just put a fuse in the wire, have a switch go to your dash, then hardwire to the cig lighter.
Or use a relay and piggy into some other fuse...like headlights or the cig lighter or seat warmer.
Chris Crash is online now   Reply With Quote
