97 Camry engine dies if RPM above 4000 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2008, 05:16 PM   #1 (permalink)
View frankcamry's Photo Gallery
Question 97 Camry engine dies if RPM above 4000
Hi,
My 97 4cyl Camry engine will die if I pushed the accelerator and let the RPM go beyond 4000 but will start again soon if I depress the gas pedal. I need to be very careful in the freeway.
The same thing happens on idle, if pushed beyond 4000 it will sputter and dies and comes on again. Fuel filter is new.
Appreciate any inputs
Thanks
Frank
frankcamry is offline   Reply With Quote
Old 09-24-2008, 06:13 PM   #2 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
hmm
This could be caused by a few diff things. However, my first guess would be a failing fuel pump.
frenum49 is offline   Reply With Quote
Old 09-25-2008, 11:15 AM   #3 (permalink)
Thanks for the input.
Is there any way that we can check the performance of the fuel pump?
Old 09-25-2008, 06:04 PM   #4 (permalink)
O-Dark-30
frenum49's Avatar
I am assuming you do not have the equipment to make the test. In this case I would goto a garage and ask them to check your fuel pressure. They will put a gauge on the fuel line to check for correct reading. Also make sure you mention that it dies around 4K RPM. If this turns out okay we can explore other avenues. Next I would start checking things like the TPS (throttle position sensor) though this is not likely to straight up kill the engine. To check the TPS you need to have a good scanner connected to the diagnostic system. Autzone does this for free I believe. Then you would make sure that the TPS % is at 0 with no throttle and at least close to 100% under WOT (wide open throttle). Also you would want to slowly push the accelerator down while monitoring the TPS % making sure that the number increases smoothly which will rule out any dead spots in its operation. Do this with the key on engine off.
