Radiator Fan not comming on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2008, 02:41 PM   #1 (permalink)
View stunnaman's Photo Gallery
3rd Generation Radiator Fan not comming on
Ok heres the situation. 95 camry 4 cyl
Fans do not come on, they do come on if AC is on.
I have replaced the following:
Radiator, Temp control switch, cooling fan raditator switch,theromstat, and coolant temp sensor.
If I unplug the wire harness that connects to the radiator fan cooling switch the fans will come on and stay on.
The only other things I may try is replacing the cooling fan control unit. If it's not that then maybe the wire harness? I didn't think it could be a bad relay because the fans will come on with AC on or like I said if I disconnect the wire harness.
I am realy getting fed up with this and I already have over $90.00 in parts I replaced that I didn't need.
Does anyone have any ideas that can help?
Oh and the enterior temp gauge is working and when I am driving the temp is ok until I stop then it will start to run hot.
So to sum it up fans not comming on when hot.
Any help will be greatly appreciated.
stunnaman is offline   Reply With Quote
Old 09-26-2008, 02:58 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Relay?
5 Lug Corolla WHAT?
Old 09-26-2008, 04:12 PM   #3 (permalink)
Can it be a relay if fan comes on when ac is on? I thought if it was relay thr fan would not come on at all.
Old 09-26-2008, 04:19 PM   #4 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
if your sitting at a stop light with the ac on, the engine is creating more heat and without any air flowing through the radiator, the fan kicks in and draw air through the radiator.. and relay was the first thing came to mind when i read the title..
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 09-26-2008, 07:51 PM   #5 (permalink)
nuchieboy's Avatar
Gameroom cash: $203299
View nuchieboy's Photo Gallery
4th Generation
yea when i read this i thought the same thing...one of my relays were shot..there are 2 fan relays in the fuse box underneath the hood...check the voltage on them
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 10-04-2008, 07:33 PM   #6 (permalink)
View illis's Photo Gallery
Same issues, problem solved.
I had almost identical problems with my 99 camry. I changed the radiator,thermostat, fan switch, and #3 relay, all of which did not correct the problem. I finally opened the radiator cap, started the car and began to see bubbles coming out. While car running I started squeezing the lower hose to only see more bubbles escape, so I topped it off with more fluid. Finally, I bled the line to remove all the air. The fans kicked on..Problem solved. Hope this helps..Good luck!
illis is offline   Reply With Quote
