New intake help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2008, 05:48 PM   #1 (permalink)
Restoring a '92 Camry
cmitchell5254's Avatar
View cmitchell5254's Photo Gallery
3rd Generation New intake help
1992 Camry LE: Hey guys. I'm still tinkering with my Spectre filter, but I want to go ahead and move up to the new intake hose and remove my stock one.
I've removed my stock air intake housing and the filter itself, just strapped up the cone filter onto the end of my existing intake hose.
My question is about the little black box that is mounted to the bottom of this hose. I assume this is the oxygen sensor....what would you recommend doing with this whole setup to be able to put in a new hose? I'm sure I'll have to do some drilling, guess I just wasn't sure what to be looking for whenever I do crack that little box open and whatnot.
Thanks again!
cmitchell5254 is offline   Reply With Quote
Old 09-28-2008, 06:39 PM   #2 (permalink)
808 State Baby
Koa808's Avatar
View Koa808's Photo Gallery
That little black box on the bottom of the Intake hose is the Resonator box. Its only use is to reduce the sound. The IAT should have been attached to your stock Filter box. its that cone shaped . The Spectre air intake tube comes with a hole already drilled in it for that IAT. You just need to find a big enough rubber ORing and use that pre cut hole. Correct me if im a bit wrong anyone
Should look like this when finished.
Koa808 is offline   Reply With Quote
Old 09-28-2008, 06:51 PM   #3 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
its an IAT sensor, not an O2 sensor ... just fyi
but x2 to the first reply
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 09-28-2008, 08:44 PM   #4 (permalink)
Well, when I removed the stock air filter setup, basically it was just a black box bolted to my body that was hooked up to the intake hjose and it had the filter inside, of course. Didn't see anything else attached to it or otherwise, unless I'm grossly overlooking something. Anybody gotta pic of this item that should have been in my stock filter housing?
