Oil leaking in 1998 Camry XLE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2008, 09:12 PM   #1 (permalink)
View brookli's Photo Gallery
Check my car (1998 Camry XLE) this morning and note that there are some oil leaking in the part (see the pictures). I have no idea about what the part is. Is it difficult to fix it?
http://i529.photobucket.com/albums/d.../leaking-6.jpg
http://i529.photobucket.com/albums/d.../leaking-5.jpg
brookli is offline   Reply With Quote
Old 09-29-2008, 02:05 PM   #2 (permalink)
Gameroom cash: $303255
It looks like you have a leaking cam cover gasket. It is not difficult to fix, but given your obvious limited automotive knowledge, you might be better off taking the car in to a pro to have it fixed. It's about $20 for the gasket, plus 1 hour of labor. The labor will depend on the labor rate of the repair shop. Either that, or find a friend to help you do this. It really is an easy repair, but you will need a 30MM socket and a torque wrench to get the proper torque on the 4 large nuts that hold the cam cover on.
Incidently, you have a 4 cylinder 5SFE engine.
Mike
