headers problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2008, 12:11 AM   #1 (permalink)
old red
old red's Avatar
View old red's Photo Gallery
headers problem
hi
i just installed my custom-made headers and after driving the car for a couple of hours, the check engine light went on
i preveously removed the catalytic converter a month earlier and there were no problems...
i saw something that looks like a small pipe coming out of the back manifold, i'm not sure if the new headers have that same pipe or not, but i'm sure that the oxygen sensors are properly fit...
so aaa what's the problem here?
Think deep, act simple.
old red is offline   Reply With Quote
Old 09-29-2008, 12:25 AM   #2 (permalink)
patrolman's Avatar
View patrolman's Photo Gallery
What engine? What year of car? All i can think of is maybe an O2 sensor or MAF sensor thats throwing a code.
1994 Toyota Camry Le
2007 Toyota Camry Se
patrolman is offline   Reply With Quote
Old 09-29-2008, 12:28 AM   #3 (permalink)
old red
old red's Avatar
2000 camry v6 manual trans.
the oxygen sensor is properly fit i'm sure of it, but there's this pipe that's originally in the back manifold, i'm not sure if they made a similer one in the new headers cause it's hard to see
Old 09-29-2008, 01:21 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359160
iTrader Score: 13 reviews
get the code read and then we can really help instead of guess
as for that pipe that was on the back of the rear header...that would be for the egr...
where did you get your headers? are they the new OBX ones that are on ebay? how's the fitment?
HaHa
Old 09-29-2008, 03:48 AM   #5 (permalink)
old red
old red's Avatar
i got them custom made... fitment is crappy, i had to go back because of a leak in a gasket
the small pipe was cancelled in the headers, could that be the problem? also, i noticed that the oxygen sensors are placed each in a single pipe before the collector, meaning that the sensor only reads the emmesions of only one cylinder... could that be the problem?
Old 09-29-2008, 04:02 AM   #6 (permalink)
TN Pussy Man
ah
and yes...unfortunately, those could all be problems.
the o2 bungs should be on the collectors so that it can get full readings from the entire bank, but that most likely won't throw a code, it just isn't good for the ecu tuning.
more than likely, you're throwing an egr code if you no longer have an egr setup with your new headers
HaHa
Old 09-29-2008, 04:12 AM   #7 (permalink)
old red
old red's Avatar
ah
ok looks like i'm goingto have to go back... but what does egr stand for?
Old 09-29-2008, 07:46 AM   #8 (permalink)
patrolman's Avatar
It stands for exhaust gas recirculation...hmmm how to put this. Its basically re-routes gasses harmful to the enviorment like nitrogen oxide back to the intake so that its not released into the atmosphere.
Old 09-29-2008, 08:06 AM   #9 (permalink)
old red
old red's Avatar
thanks for the info... what happened is that they cancelled it from the headers and blocked the flang, you think this's what caused the check engine light?
Old 09-29-2008, 09:31 AM   #10 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
It keeps your combustion temperature down by re-using the inert gas from the exhaust back through the combustion chamber. Also helps with your NOx emissions.
BlueFusion6851 is offline   Reply With Quote
