Less-Messy Oil Change? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2008, 03:15 PM   #1 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
idk why im just now asking this ... but does anyone have any tricks on removing the oil filter without having oil pour down the block? it seems every time i change my oil, i end up having to wash the engine bay because i make a mess
just wondering...
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 09-29-2008, 04:05 PM   #2 (permalink)
The Connoisseur
CharmCityES's Avatar
heres what i do at work....it works most of the time
it really depends which oil filter base the engine has, because some have better drainage than others
loosen the oil filter a bit, but dont let any oil drain out...then, take a hammer and punch and poke a hole or two in the top of the oil filter...make sure the filter is slightly loose or this wont work...then, remove oil cap and dipstick, then drain oil completely....when you go to remove the filter, the oil will have escaped down the oil filter housing and out the drainpan, thus there shouldent be any leakage onto the block
this process works on only the 5SFE camry/celica motor and 1GRFE truck motor
The "Executive Sedan"
Old 09-29-2008, 05:44 PM   #3 (permalink)
340,000 miles+......
sk8ersublime's Avatar
View sk8ersublime's Photo Gallery
i always make a mess and bitch about it. :\
http://www.cardomain.com/ride/2915998
340,000+
sk8ersublime is offline   Reply With Quote
Old 09-29-2008, 10:03 PM   #4 (permalink)
Kisuke in rain
Mazeraski's Avatar
View Mazeraski's Photo Gallery
Usually I'll let mine drain with the oil cap off and dipstick out. Plus I let it drain until it barely drips from the pan. That's been working for me
Just in case, I put a rag around it when I'm taking it off, but the last couple of times I've done it the filter has been pretty much empty.
1992 Toyota Camry LE 5SFE 4 cyl. 2.2L
A.K.A. "Ron Burgundy"
198,000 mi. (as of February 9th, 2010) and counting
Mazeraski is offline   Reply With Quote
Old 09-29-2008, 10:26 PM   #5 (permalink)
i go both ways-mac and PC
ghettosled's Avatar
Gameroom cash: $128595
i let my car sit for a little bit before i change the oil. i drain the pan with the cap and dip stick out before i change the filter. i have never had oil drip down the outside.
Old 09-29-2008, 10:30 PM   #6 (permalink)
Venom_5's Avatar
weird, i guess its cuz i usually do it when its warm ...
and at work we change the filters on the cars soon after they roll in, so theyre hot too and they drip .... nothing too bad, but enough to notice on the block
Old 09-29-2008, 10:31 PM   #7 (permalink)
Restoring a '92 Camry
cmitchell5254's Avatar
View cmitchell5254's Photo Gallery
Unscrew your filler cap and pull out your dipstick. Drain the engine itself before doing the filter, then just slide your pan underneath where the filter is. This should at least minimize the amount of oil that makes it onto yer block.
cmitchell5254 is offline   Reply With Quote
Old 09-29-2008, 11:12 PM   #8 (permalink)
Venom_5's Avatar
ill try it on the first camry that comes into work tomorrow ... see if that works when its still hot
Old 09-30-2008, 09:24 AM   #9 (permalink)
Heat's Avatar
View Heat's Photo Gallery
Originally Posted by CorCamrySE View Post
... loosen the oil filter a bit, but dont let any oil drain out...then, take a hammer and punch and poke a hole or two in the top of the oil filter...make sure the filter is slightly loose or this wont work...then, remove oil cap and dipstick, then drain oil completely....
I'll have to try this next time. I just changed the oil in my car ('95 LE I4) this past weekend and of course had oil drip (pour) down from the filter.
One trick I've picked up on is to stuff a few paper towels into that little spot just under the filter to help catch some of the oil.
Heat is offline   Reply With Quote
Old 09-30-2008, 05:05 PM   #10 (permalink)
Tom 2000's Avatar
Gameroom cash: $189850
View Tom 2000's Photo Gallery
There's a very simple trick to a clean oil change on the 5S-FE (3S-FE as well).
Remove drain plug to drain the oil. WAIT 30 MINUTES before you remove the Oil filter from the block.
That's it. Block stays dry and works everytime.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 09-30-2008, 08:01 PM   #11 (permalink)
Venom_5's Avatar
psh, i dont have 30 mins ... im used to 10 mins or less for an oil change
ill probably just stuff some towels in there and cry about it later ... have only had 1 day off in the last 2 weeks, my next day off is friday - i need to order rotors & pads and knock this oil change out of the way
Old 10-05-2008, 10:19 AM   #12 (permalink)
forever 2 wheels's Avatar
View forever 2 wheels's Photo Gallery
3rd Generation
Before you remove the oil filter, place a plastic shopping bag over filter. Unscrew filter and catch oil and filter in bag! I also liked the idea of punching two holes in top of filter and let drain. I will try that out next change, thanks CorCamrySE.
1996 Camry LXS V6 154K miles, vehicle for sale!
forever 2 wheels is offline   Reply With Quote
Old 10-06-2008, 06:32 PM   #13 (permalink)
Venom_5's Avatar
i loosened the oil filter, removed dipstick & oil cap ... drained the oil, then removed the filter and still made a small mess ... oh well, i washed the block off and its fine now
Old 10-06-2008, 09:51 PM   #14 (permalink)
camrys blow off too!
View silverstreakin's Photo Gallery
wait till its cold. the downpipe is freakin hot! i let it sit overnight
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
silverstreakin is offline   Reply With Quote
Old 10-06-2008, 10:46 PM   #15 (permalink)
Venom_5's Avatar
meh, i work at an oil-change place so im used to burns and scratches .... my hands look like that of a 60-yr-old mechanic
