SC noise and vibration fixed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2008, 09:21 PM   #1 (permalink)
View ChaneyTsai's Photo Gallery
4th Generation SC noise and vibration fixed
Nothing big but just want to share my experience fixing my AC noise and vibration problems.
Ever since I installed TRD supercharger, my car vibrated much more than before and when AC kicked in, there was a noise and more vibration. After some investigation, I think the SC belt tensioner may be the problem since it moved much more when AC in on than off. So I ordered new tensioner and belt and a new idler pulley for tensioner. Yesterday I spend one hour to replace them and after that the noise is gone. New tensioner is not moving that much than the old one so it's obvious that old tensioner is going bad.
I also found that I over torque the dogbone bolt causing excessive vibration when AC kicked in. Since I retorqued it, no more annoying vibration when AC is on, only one or two seconds then back to normal. The car still vibrates a little bit more before I installed SC but it's not too bad.
BTW, I also fixed P0401 CEL. It's bad VSV. That VSV looks good when I test it but it actually didn't open up enough to allow enough vacuum to pass. This again proved the VSV may look good when test it but it's actually failed.
2001 Camry XLE, TRD Supercharger, Jim's fuel mod, Eibach Pro Kit, Tokiko struts, Hayden ATF cooler, NGK Irdium spark plugs
ChaneyTsai is offline   Reply With Quote
Old 11-14-2008, 05:04 PM   #2 (permalink)
View Garlo's Photo Gallery
Where have you bought new tensioner and belt and a new idler pulley for tensioner ? At your local Toyota dealer or what ? links ?
Garlo is offline   Reply With Quote
Old 11-14-2008, 07:32 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359260
iTrader Score: 13 reviews
Toyota will take a long long time to find the parts for you depending on how good your parts ppl are....it took my local dealership 4months to track down the part numbers for one of the smooth pullies for me...and it ended up being a dayco one anyway...
so, here are the dayco part numbers- you can either find a local distributor that carries dayco parts, or order them from somewhere online. Not sure which one is easier for you in denmark.
89007 = Smooth idler pulley w/o flange
89009 = 6-groove" idler pulley
89203 = Belt-Tensioner
For the belt-tensioner there, it will come with a different pulley on it. You can either reuse your old one on it, or you can buy a new smooth idler pulley and slap that one one.
Dayco also carries the belts. The best ones for our application are the polycog belts.
The stock belt size is supposed to be 89.5", so the part number for that would beayco Poly-Cog 5060895
For the ppl who don't have a tensioner and has the old belt setup, the belt size is supposed to be 88", so that part number would be 5060880
I hope that helps
HaHa
Old 11-14-2008, 09:09 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $511687
iTrader Score: 27 reviews
View bigbird's Photo Gallery
hope you have better luck with your tensioner. my was wasted after 2 days.... but yeah from my gen4 to gen 3 the new(even busted)tensioner was MUCH smoother and quieter. id honestly rather have the old idler system without the tensioner.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
bigbird is online now   Reply With Quote
Old 11-15-2008, 05:53 AM   #5 (permalink)
JvR
JvR's Avatar
View JvR's Photo Gallery
look what i found:
http://s32.photobucket.com/albums/d2...0from%20DAYCO/
JvR is offline   Reply With Quote
Old 11-15-2008, 11:47 AM   #6 (permalink)
Gameroom cash: $846000
View ASG14's Photo Gallery
Wow, so thats what the Sienna idler plate looks like!
Chaney, good info.
'95 Corolla AE101...
Old 11-15-2008, 12:59 PM   #7 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
Should I replace any of these if I do my next timing belt change. I am at 270k, probably change after 30k
92 Camry 4 cyl 5 Spd
330,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
