Help Radiator Fans won't cut off??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2008, 04:56 PM   #1 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
3rd Generation Help Radiator Fans won't cut off???
Well I don't know how it happen, but everytime I turn over the ignition, but I don't crank the engine up it comes on. I not complaining about it much its a big power drain. I don't know if it might be come a problem in the future, so should I leave it alone or try and fix it. All of this happened when I was installing reverse gauge, but I haven't wire it up yet do to that problem and the needle getting stuck. That problem I've already fixed... My main problem is with the radiator fans!!
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 09-30-2008, 07:13 PM   #2 (permalink)
just a nobody
Check the coolant fan switch, it may be disconnected or open.
N.E.O.
Old 09-30-2008, 07:17 PM   #3 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
one time my 97 camry 4cyl radiator fan turns on as soon as i turn the igition key to ON, not even start the engine, AC or heat/FAN off, and fan runs continously as i drive, i did all the diagnostic, turn out my coolant temperature sensor at the buttom of the radiator malfunction.
bronzemaxell is offline   Reply With Quote
Old 10-01-2008, 12:05 PM   #4 (permalink)
JayMax03's Avatar
N.E.O.
where is that on a Gen3 Camry?
Isn't that at the bottom of the fans? The fans work, but it stays on all the time. I don't know what caused it, and my temp gauge works just fine
Old 10-01-2008, 12:33 PM   #5 (permalink)
just a nobody
5sfe should be on the thermostat housing below the alternator. Temp gauge use a different sensor, this one is a switch, it opens up when it gets up to somewhere around 191 degree F.
N.E.O.
