very bad vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2008, 08:43 PM   #1 (permalink)
View kendallKICKASS's Photo Gallery
4th Generation very bad vibration
ok so a few weeks ago after coming back from ATL i felt a vibration when i pushed the brakes but some reason i didnt pay attention to it. now it gets so bad i have to pull over and wait and it does it when im braking and when im not. i was thinking its the rotors b/c when ever you stop and there water on them you hear and see the water evaporating.
have anyone else had this problem or know how to fix it
1997 Camry V6 - 86k rebuilt engine(mine and moms)
1991 Accord EX - 325,XXX(mine and moms)
06 Lexus GS430 - 50k(mine) 03 Lexus GS430 - 78k(mine) 01 Lexus LS460 - 84k(moms) 05 Lexus ES330 - 54k(moms)
kendallKICKASS is offline   Reply With Quote
Old 10-01-2008, 09:41 PM   #2 (permalink)
Gameroom cash: $152705
View redgtxdi's Photo Gallery
Ya, sounds like rotors.
Assuming that's the case, I would have to say that I don't like turning rotors that are warped. (Heck, I don't like turned rotors at all) And since decent rotors can be had for fair money, I say just go get some new ones.....clean them thoroughly w/ brake parts spray.......and install.
New rotors are sooooo nice!! Smooth as silk.
redgtxdi is online now   Reply With Quote
Old 10-01-2008, 10:14 PM   #3 (permalink)
just a nobody
Didn't you said it vibrates whether you are braking or not? If so, it is not your rotor, you might want to check your tires or suspension. How fast do you have to drive before you feel the vibration?
N.E.O.
Old 10-02-2008, 12:24 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
What does pulling over and waiting do?... does the pulsing stop for a while?
Not sure what you're saying... if you throw water on the rotors you get some steam off them?
BMR is offline   Reply With Quote
Old 10-05-2008, 09:32 AM   #5 (permalink)
i have to stop and let the driver side rotor cool b4 i take off.
yea but its not some steam its ALOT of steam
Old 10-05-2008, 09:33 AM   #6 (permalink)
N.E.O.
between 35-50
and above 60 sometime
Old 10-05-2008, 10:17 AM   #7 (permalink)
just a nobody
between 35-50
Were you using the brakes then?
N.E.O.
Old 10-05-2008, 10:40 AM   #8 (permalink)
yea but it will do it after i let up off the brakes
but im taking it to the toyota place today so they can start looking at it and fix what ever it is thats f**kin with my baby
Old 10-05-2008, 10:46 AM   #9 (permalink)
just a nobody
So it happens even if you are not using the brakes?
How are your tires? Worn? New? In between? Your description seems to point to problem with your tires, maybe out of balance or broken belt.
N.E.O.
Old 10-05-2008, 12:22 PM   #10 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
My guess?... sounds like the pistons in your brake calipers are sticking and not letting the brakes free up. That would cause the rotors to heat up, and in your case, warp and cause the vibration you're feeling.
