Oil Pan Leak need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2008, 11:26 PM   #1 (permalink)
View hassanbigboss's Photo Gallery
Hey everyone. My 1998 Camry V6 with 180.xxx miles has a slight leak in the oil pan gasket. I want to change it myself and want to know that what kind of sealant is used on the gasket? Thank
Has
hassanbigboss is offline   Reply With Quote
Old 10-03-2008, 12:10 AM   #2 (permalink)
just a nobody
Toyota FIPG. The original sealer was gray, and the new stuff is black. Which one is leaking? Upper or lower?
N.E.O.
Old 10-03-2008, 07:26 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i only used high temperature RTV (the red stuff with no gasket). works like a charm.
Old 10-09-2008, 03:32 PM   #4 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
What is the brand and where do you pick it up? Is this equal to or better than Toyota OEM? I will drop my pan this weekend.
04 SC430 05 RX330
96 Camry LE T-boned Oct. 09 RIP
mandyfig is offline   Reply With Quote
Old 10-11-2008, 01:04 AM   #5 (permalink)
N.E.O.
its the lower seal, the leak is towards the back of car
Old 10-11-2008, 01:41 AM   #6 (permalink)
just a nobody
The black one? When you said the leak is towards the back of the car, do you mean the area above the drain plug? Some time the oil around there is from the oil filter during an oil change. On high mileage engine, it could also be from the cam seal if it is just the rear corner of the pan towards the front of the engine.
N.E.O.
Old 10-11-2008, 03:59 PM   #7 (permalink)
N.E.O.
I know exactly what you are saying but its is the oil pan seal, and not the oil from changing the oil filter or from the cam seals, I checked them all to make sure it is the pan gasket but I will look again to make sure
Old 10-11-2008, 05:16 PM   #8 (permalink)
just a nobody
As long as you are aware of it, that would be fine! Just double checking.
N.E.O.
