How to replace the sparkplug tube seal (V6)? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2008, 08:58 PM   #1 (permalink)
View sjcruiser's Photo Gallery
Hi all,
How do I replace the tube seals back to the valve cover? There are two notches on the back of the valve cover that I could not squeeze the seals pass through as these seals seem to have a metal outer ring
This is for '96 Camry V6 (1MZ-FE).
Could someone please help?
Frank.
sjcruiser is offline   Reply With Quote
Old 10-04-2008, 01:04 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
you have to bend the tabs back, and then use a screwdriver to take the old grommet out
it'll break up and you'll have to take it out piece by piece usually
then put in the new one, use a mallet to get it all down if needed (evenly) and then bend the tabs back
HaHa
Old 10-04-2008, 02:36 AM   #3 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
I hammer them out from the topside of the valve cover using a socket that is just barely smaller than the tube opening. this bends the tabs for you and is absolutely the easiest way i've found to do it. once the seals are out, bend the tabs straight up with needle-nose pliers before installing new seals.... and tap them back down with a flat screwdriver and hammer when you're done.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 10-04-2008, 10:05 AM   #4 (permalink)
Ah, I see it now...
Thanks guys for the quick responses.
Regards,
Frank.
