1999 Camry Realy Starter Power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2008, 09:20 AM   #1 (permalink)
View kjsjd27150's Photo Gallery
I have a 1999 Camry and the starter relay is not being energized when I turn the ignition key. I can short the starter relay and start the car that way (I also replaced the starter relay for good measure - good use of $70!!). I'm wondering if the culprit is the ignition switch or the clutch starter switch and if anyone has any info on wiring and replacement and which solution I should investigate first.
Much Appreciated.
kjsjd27150 is offline   Reply With Quote
Old 10-04-2008, 12:14 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check the Starter fuse also. Fuse box behind drivers side instrument panel.
Not sure where the clutch switch is, might be up under the dash. Has a Black/White wire and either a Black/Orange or Gray wiring running to it.
