Airbag light... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2008, 04:35 PM   #1 (permalink)
Tech In Training
View Gun5's Photo Gallery
Airbag light...
Well first let me say the car when I first got it didn't have the airbag light illuminated... and it hasn't been wrecked ect... I'v done all the seals on both sides of the motor and all the belts... is there a plug under the hood I unplugged probably?
I want to get this fixed ASAP since my girl drives this car 45 miles a day
2000 Camaro Z28 - Full Bolt ons, Heads/Cam
1994 Firebird Formula - Full Bolt ons, Heads/Cam *Parted Out*
Coming Soon 1995 Camry LE 165k
Gun5 is offline   Reply With Quote
Old 10-04-2008, 04:44 PM   #2 (permalink)
just a nobody
Check the codes first. The airbag wiring connectors should all be yellow.
N.E.O.
Old 10-05-2008, 02:41 AM   #3 (permalink)
Tech In Training
can a regular scanner pull the thing.. i hate the blinking light things... or does it have to be a different kind of scanner
Old 10-05-2008, 09:01 AM   #4 (permalink)
just a nobody
An OBD scanner won't work for the airbag. There is a way to retrieve the code by count the number of blinks of the SRS light after jumping the E1 and TC terminals in the DLC1 connector in the engine compartment, however, I cannot be 100% sure if those are the terminals.
N.E.O.
Old 10-05-2008, 10:56 PM   #5 (permalink)
View zwfly's Photo Gallery
I have the same issue as well
zwfly is offline   Reply With Quote
Old 10-05-2008, 11:54 PM   #6 (permalink)
just a nobody
Check the code, then maybe you can do something about it.
N.E.O.
Old 10-06-2008, 12:48 AM   #7 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
What I would ask too is did you do anything to any of the wiring in the car?
I did to mine which caused it to fry the control module. I had a problem with my stereo/antenna and somehow tripped the light on. There's a way of clearing the light on it, [ http://www.toyotanation.com/forum/t16839.html ] but when we tried we got a 134 code I think it was? or something. Midnightmach knows. Anyways, I ended up having to get a new one. Once we put it in, we tried again. After a couple tries we were able to clear it. When it actually clears the code, then it'll blink fairly fast then stop and all is well again.
In case you need to replace the control module though, it is located underneath the middle console on the back end of it.
Definitely see what your code your getting though if it won't clear.
cykaaro is offline   Reply With Quote
Old 10-06-2008, 05:03 AM   #8 (permalink)
Tech In Training
I did install a Sony Mp3 CD player the 2nd day we had the car... that might have been it.. although the radio and antenna have been working just fine and I believe I had power off when doing it..
whats the right way to read the code with the blinking on the dash.. I have looked at alldata and they are showing engine codes and such not the SRS system
Old 10-07-2008, 01:06 AM   #9 (permalink)
Tech In Training
buumpppp
Old 10-07-2008, 01:35 AM   #10 (permalink)
just a nobody
Ah, the one who doesn't replace the trans drain plug gasket!
Anyway, count the number of blinks of the airbag light and look for the pause in between, they are usually two number codes; in other words, if it is a 43, it will blink four times short pause and blink three more times, then a slightly longer pause before it blinks out the next code if any. It will repeat itself after it has been through all the codes.
N.E.O.
Old 10-07-2008, 02:51 AM   #11 (permalink)
Tech In Training
N.E.O.
haha hey if done properly you shouldn't have to... someday when it leaks ill change my statement but so far iv done well over 60-70 transmissions (auto & manual like this)
on the codes do i have to jump the OBD port?
Old 10-07-2008, 03:04 AM   #12 (permalink)
just a nobody
Hey, like I said to the others, it is your car, you can do whatever you like. However, on a forum like this, I just try to make suggestion that would minimize any future complication.
The one under the hood would be easier to get to, the terminal are the ones above.
N.E.O.
Old 10-07-2008, 03:19 AM   #13 (permalink)
Tech In Training
N.E.O.
haha I got ya ... ill see what they tell me in auto transmissions class its the only automotive class I got left (i'm 95% through my automotive degree atm)
Old 10-07-2008, 03:32 AM   #14 (permalink)
just a nobody
Toyota T-ten?
N.E.O.
Old 10-07-2008, 03:39 AM   #15 (permalink)
Tech In Training
Toyota T-ten?
N.E.O.
general automotive BUT i do take the electrical classes in the toyota funded building haha.. my school has 2 programs general and toyota t-ten ...
