There is a system of "doors" that open and shut to direct the air flow from the floor to defrost, dashboard, etc. It sounds like something has gone wrong in your system.
I'm with NEO that usually the side and middle vents act together. But I think it requires a combination of "doors" working in conjunction with each other. If only one failed it might result in only the center vent problem.
Not sure but thought I'd mention it.
Kep
