weird noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2008, 02:33 AM   #1 (permalink)
sexy, dirty, and slow...
93XLEcamry's Avatar
View 93XLEcamry's Photo Gallery
3rd Generation weird noise
i dont know what this weird noise is....when ever i break a hear like a clunling sound from the back of my tires???...not really sure what that noise is...but my break light is on...and i checked everything....fluids, pads, but still on...not sure if light has anything to do with the cracking noise...plz help
93XLEcamry is offline   Reply With Quote
Old 10-05-2008, 09:06 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Two points. The first is pretty easy, the brake light comes on when you get low on brake fluid. Check your brake reservoir fluid level. It is probably low.
The second point is more drawn out. I am guessing that the noise is due to overly thin (maybe even dangerously thin) brake pads. I come to that because of the two symptoms together and a personal experience. As the brake pads wear thin it takes more fluid to engage them. This drops the level of the fluid in the reservoir and the brake indicator light comes on. In my case I didn't realize this and I kept adding brake fluid (to get the light to go off) and didn't check my pads. One day when making a turn and braking at the same time the pads on my right side fell out and I lost my brakes entirely. I was extremely lucky that there was no one else in the intersection and that I could coast to a stop. Kind of scary.
Anyhow, check your brake pad thickness all around. It isn't difficult to do yourself.
It would also be helpful to know what model year the car is, how many miles it has and what brake service you have had done to it.
Kep
Old 10-05-2008, 09:29 AM   #3 (permalink)
just a nobody
Have you check your parking brake to make sure that it is not engaged half way?
N.E.O.
