Gas Tank Door Spring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2008, 07:59 PM   #1 (permalink)
View jderrick's Photo Gallery
The spring on the gas tank door flap on my 1999 Camry has died. Right now I just jam something under the latch and then pry open the door, which works fine, but I'm wondering if anyone else has had this problem and how they solved it.....
jderrick is offline   Reply With Quote
Old 10-05-2008, 10:41 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
They sell foam weather stripping (sticky on one side) for windows and air conditioners. I've always thought that it would be possible to stick a 1' piece or so on the gas door so when you shut it the foam would compress on the spot where the spring used to be. I'm not sure how well this would work but it should. They make a 1"x1"x4' air conditioning weather strip that a small 1"x1"x1" cube might work real well.
Kep
Old 10-05-2008, 11:00 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Napa has the part and the dealer should also. I don't remember the price, but it should be about $5 to $10.
2007 Camry 2.4L 5M
Old 10-06-2008, 01:35 AM   #4 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
i have also seen the big paper clips used, the wide black ones for clipping whole stacks together
rebel8ball is offline   Reply With Quote
Old 10-06-2008, 11:08 AM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Try napaonline or dealer. It used to be about $5.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 10-06-2008, 11:09 AM   #6 (permalink)
Old 10-06-2008, 02:44 PM   #7 (permalink)
Well, this'll be my next little project. Thanks everyone!
JD
Old 10-06-2008, 08:13 PM   #8 (permalink)
View lenjack's Photo Gallery
Common repair item. mine was less than $4 at dealer. 30 second do it yourself repair.
Any car problem can be fixed with a large enough hammer!
lenjack is offline   Reply With Quote
Old 01-02-2009, 03:30 PM   #9 (permalink)
Stock Nazi(ish)
gregorv's Avatar
View gregorv's Photo Gallery
Canada
I think this is a common problem on Gen 4's. I have a 1999 Camry and my dad has a 1998, both have this issue.
1999 Camry, 3 litre V6 Auto- 330 000 km
gregorv is offline   Reply With Quote
Old 01-02-2009, 03:35 PM   #10 (permalink)
When I went into the dealership and asked for the spring, the guys at the counter knew immediately what I was talking about, referred to it as "The Devil Spring," and, sure enough, it cost exactly $6.66.
Old 01-02-2009, 03:43 PM   #11 (permalink)
Stock Nazi(ish)
gregorv's Avatar
Canada
I just called my local Napa and they said $5.50. Also told me that it wouldnt get here for 4 days...I think I'll call the dealer tomorrow.
Old 01-02-2009, 09:05 PM   #12 (permalink)
lol!! I love it. Easy fix...ask me how I know.
