Gen 3 shifting weird - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2008, 10:02 AM   #1 (permalink)
White Stripes
omegarex's Avatar
View omegarex's Photo Gallery
Hello I've searched, but did not find the solution,
1993 Camry v6, with around 155,000 miles, auto trans.
Just recently my car has been shifting funny, for example I'm on the highway, going around75-80mph at nearly 3k rpm, then all of a sudden it down shifts gears and then its shoots up to 4k rpm at 80ish, but the thing is, the car seems confused of what gear it should be in so it shifts up again, and then down shifts then up shifts. This occurs at almost all shift point in between gears. If you dont get it, just pretend you are driving normally, and you know when your car usually shifts down, imagine you are at that point and you keep your foot steady at that stage, now the problem is that car doesn't know what gear it should stay in. Please assist, because I'm not sure what it is, or what to check for. Thanks.
93 Nitrous Camry
06 4runner
omegarex is offline   Reply With Quote
Old 10-06-2008, 11:24 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
did you try checking your kick-down cable that's attached to the tranny?
HaHa
Old 10-06-2008, 01:39 PM   #3 (permalink)
White Stripes
omegarex's Avatar
ill check once i get out of work. I adjusted it early this summer, i'm not sure how tight it should be. Either way, does it sound like an actual tranny problem? I'm not sure what a bad auto transmission would do if its going bad, which is why I'm curious.
93 Nitrous Camry
06 4runner
Old 10-06-2008, 02:30 PM   #4 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
There are too many symptoms to list that a tranny can have if it its "Going Bad". In most cases the trans will slip, RPM goes up car does not accelerate. Sometimes the trans will not go into over-drive or will not shift past 1st or second etc. Gear box mechanical damage, a lot of grinding, gear whine etc. None of these symptoms equate to a tranny going "bad". Just needs work. I think gear box damage would be the worst case scenario for a bad trans. I think Eye8pussies got it right with the kick-down. No offense but, the fact that you had adjusted the cable enforces the opinion.
frenum49 is offline   Reply With Quote
Old 10-06-2008, 02:40 PM   #5 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Double check the fluid level.
can also be sign of C0 clutch failure[common on A540 transmission
Doctor J is offline   Reply With Quote
Old 10-06-2008, 03:10 PM   #6 (permalink)
White Stripes
omegarex's Avatar
stupid question right here but i have to ask, will improper gapping of spark plugs cause this problem? I recently changed my plugs and considering my plugs are gapped at .035 for nitrous safety, would that affect it. my answer would be no to my question, but my knowledge is limited by the information i read online, credible or not, which is why i turned to you guys. i will definately check the kick down cable, if not ill check the trans fluid, btw I never changed the trans fluid ever since i owned this car.
93 Nitrous Camry
06 4runner
Old 10-06-2008, 03:16 PM   #7 (permalink)
Doctor J's Avatar
this may affect engine prformance or shift timing; but it should not allow transmission to drop down one gear while cruising.
Old 10-06-2008, 03:29 PM   #8 (permalink)
White Stripes
omegarex's Avatar
i understand that it will affect engine performance, but shift timing? how so
93 Nitrous Camry
06 4runner
Old 10-08-2008, 06:34 PM   #9 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
155,000 miles and NEVER had a tranny fluid change??!?!?!?!
Hint: Start there.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 10-08-2008, 07:40 PM   #10 (permalink)
White Stripes
omegarex's Avatar
it was the O/D button, I noticed the O/D light flicker on and off while driving, so basically it was the wires touching each other because of the vibration of the car. And do i really have to change tranny fluid? Not to sound like a noob or anything, but my friend, who is a mechanic said don't change it because of something, he gave a reason but i forgot what it was, so i was like okay i wont change it. and so far, i haven't had any tranny problem and i run nitrous through the shifts.
93 Nitrous Camry
06 4runner
Old 10-08-2008, 07:47 PM   #11 (permalink)
Do not buy from
View Zviator's Photo Gallery
The cam made it that long ??? I bet u the ATF dip stick is blacker than my BBQ grille.
Zviator is offline   Reply With Quote
Old 10-08-2008, 07:50 PM   #12 (permalink)
View toyomoho's Photo Gallery
Did the mechanic states something like: If you change the fluid now it was cause problems, or the old fluid has grit in it that helps the clutch plates grip and the new fluid will not, or changing the fluid will allow all the old debris to break loose and cause problems?
The issue is changing the fluid may or may not cause problems (not talking about a flush) but leaving the old fluid in will sooner or later cause trans failure.
Old 10-08-2008, 07:52 PM   #13 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
He must have said something like, new fluid will destroy the trans, or it will make the trans leak, right? Your friend is a fool. How long has he been a mechanic? My friend, also a mechanic, has been in the game for 40 years. He has never once told anyone not to change the fluid in an old trans. Change that fluid A.S.A.P.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 10-08-2008, 07:54 PM   #14 (permalink)
Do not buy from
3rd Generation
Yeah right, I see u got a good friend right there, he sure will take care of you well next time u call him for a tow because the tranny fucked up.
My dad used tell me the same thing: "dont change the fluid, just make sure it's full". He drives a ford, and obviously read them off the mannual. No wonder most american cars never made it through 5 years.
Old 10-08-2008, 08:13 PM   #15 (permalink)
uibalnme's Avatar
+1
