Sure, by 100K miles these wear items (oxygen sensors) should be replaced.
It's better to verify the cat performance like in emissions check. But generally if the engine is well tuned, there are no air leaks or exhaust leaks upstream of the cat, then I'd suspect the oxygen sensors first.
I'd recommend Bosch planar types. These are more resistant to contamination than older thimble types:
http://www.boschautoparts.com/Produc...nsors/PlanarO2
Originally Posted by basil
I've got a 96 Camry with the 5SFE four cyl with 113k miles. The check engine light comes on from time to time, and shows a P0420 (catalyst efficiency below threshold). Once I clear the code, it'll take it 2-3 months to return.
My question is this: it seems that the rear O2 sensor is the most likely culprit, considering the mileage on the car (low for its age, but more than 100k) and the fact that the light stays off for a while. It seems that if it were the catalytic converter, the light would come back on much faster after being cleared.
Is this correct, or does something thing the converter is the more likely cause?
Right now, I'd rather not replace both the converter and the rear sensor.
Thanks.
