My 01 Camry 5S-FE has 123,000 miles. I want to try synthetic but I'm not sure what viscosity to go with. My car has no leaks and oil consumption that I know of.
I've just tried Ow-30 Mobil 1. I've not done oil analysis yet but it gets flowing very quickly on cold start-up. Mobil says it meets or exceeds 5w-30 or 10w-30.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
The owner's manual says 5W-30 but I heard 10W-30 is better for high mileage engines.
That's because higher mileage cars might have leaks or burn a little oil. If your engine doesn't have any problems you should be fine with 5W30. Usually people use 5W30 in the winter and 10W30 in the summer. My gen 4 manual has a graph with 5W30 for low temps, and 10W30 for high temps.
i'lve been using 5w30 all year around.. as hot as 110+ and as cold as low 20s...
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
A little bit OT, but there shouldn't be a problem in switching viscosities, is there? Between 5W-30 and 10W-30, that is.
nope.. not really...
manufacture dont recommend mixing brand but you can... the manufacture perfred if you stick to one brand of oil..
Note that the difference between 5W and 10W is the Cold Cranking Viscosity at -25C vs -30C. If you are in California, Texas, Florida, etc, its not going to make any difference. The reason 10W-30 is preferred over 5W-30 for some high-temperature and high-mileage applications has to do with base oil and additive chemistry. Multigrades are manufactured by taking a thin base oil mixture and adding polymers that dont allow it to thin out as much at high temperature. Pour point depressants are added to keep wax crystals from forming and thickening the oil too much at very low temperatures. The problem is that a thinner base oil tends to oxidize and evaporate more easily, leading to higher oil consumption and possible sludge if drain intervals are pushed way to far, like 10k miles. Note that oil chemistry has vastly improved over the years, so these issues are much less than even just a decade ago. Synthetic 10W-30 is really straight 30 that happens to meet the low temperature spec without any polymers. I dont use syn because it simply is not worth the extra money (2-3x) due to the vast improvements in conventional oils in recent years.
