Rubbery burning smell - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2008, 03:09 PM   #1 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Whenever my engine reaches normal operating temp, there is a strong smell of burning rubber from the engine bay. I cannot see any smoke or anything that looks like it's burning.
I don't really know what it could be. It's not burning oil, it's not burning clutch, it's not burning gear oil. Any ideas?
Chris Crash is online now   Reply With Quote
Old 10-09-2008, 05:59 PM   #2 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
hmmm
Inner fender wells rubbing on the tires when wind pushes them forward? Serpentine belt rubbing on a loose timing belt cover or other obstruction? Timing belt itself rubbing on the plastic timing cover? Have you been rubbing too hard on your polyester Hammer pants? CANT TOUCH THIS?
frenum49 is offline   Reply With Quote
Old 10-09-2008, 06:44 PM   #3 (permalink)
Well I know it's not the tires. How do I find out if it's the timing belt? Take off the cover and look?
Old 10-09-2008, 06:47 PM   #4 (permalink)
O-Dark-30
frenum49's Avatar
If the timing cover is not loose it is not likely rubbing there. Might want to make sure there is no wiring or loom that is touching a hot spot on your exhaust or manifold somewhere.
Old 10-09-2008, 08:54 PM   #5 (permalink)
View zwfly's Photo Gallery
if it was driving condition, i guess break calipers. I had exactly same problem before. The malfunction of calipers makes break pad very hot, and transfer heat to tires. very dangerous since tire may loose at high temp.
zwfly is offline   Reply With Quote
Old 10-09-2008, 09:31 PM   #6 (permalink)
O-Dark-30
frenum49's Avatar
Good point...check your rims after you have driven to see if any one of them are hot. If so your calipers are dragging on that particular wheel.
Old 10-09-2008, 09:36 PM   #7 (permalink)
View importcar's Photo Gallery
Could spark plug wires touching the valve cover cause a burnt smell?
2001 Camry LE 5S-FE
importcar is offline   Reply With Quote
Old 10-10-2008, 08:01 AM   #8 (permalink)
O-Dark-30
frenum49's Avatar
No.
Old 10-10-2008, 08:35 AM   #9 (permalink)
View proftomda's Photo Gallery
USA
Many heat sources that can generate a burning smell. The most common is oil leaks on the exhaust pipe but you said it was definately a burning rubber smell. That eliminates a siezed brake caliper, oil leaks, coolant leaks, shorted wiring or arcing because they all have a specific smell different than burning rubber. If indeed burning rubber, you need to verify all hoses and electrical conduits are safely away from heat sources.
proftomda is offline   Reply With Quote
