Creaking Noises! Bushings? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2008, 06:47 PM   #1 (permalink)
View MattInLA's Photo Gallery
Hi my 1997 4 cyl 185K miles is making a lot of CREAKING noises in front when it goes up and down driveways, uneven surfaces or stops or starts. Sounds just like a creaky door! (Not shocks, that an shock mounts were replaced and I know what those noises sound like) So I brought it to some places they say its the lower control arm bushings. $350 to remove control arms and press on new bushings vs. go buy some new control arms with bushings and install those. I would like to get some opinions on this, thank you. Is this something I can do is this basic nuts and bolts or more involved thanks.
MattInLA is offline   Reply With Quote
Old 10-11-2008, 07:37 PM   #2 (permalink)
just a nobody
Check the sway bar bushings first.
N.E.O.
Old 10-11-2008, 08:23 PM   #3 (permalink)
View importcar's Photo Gallery
My 01 Camry with 123K mi makes creaking noises up front as well. It also feels kind of loose, like some nuts and bolts aren't tight. When I brought my car to the dealer for the 90K mi service, they said I needed new front struts and towers at a cost of $1100. I knew they were worn but they don't bounce or dive either.
2001 Camry LE 5S-FE
importcar is offline   Reply With Quote
Old 10-12-2008, 03:56 PM   #4 (permalink)
struts and towers
? Check carefully! It's seems like it's struts when you BOTTOM OUT and POUND over potholes and as for STRUT MOUNTS, those RATTLE when they go because the bearings are shot. But CREAKING I believe is BUSHINGS always!
RE: replacing my OWN bushings. Is this too advanced for me? Do I need to go out and buy HUGE metric sockets to do this?
Old 10-12-2008, 04:01 PM   #5 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
N.E.O.
I'd say check that 1st as well. Try to go with the cheap things 1st.
5 Lug Corolla WHAT?
Old 10-12-2008, 11:57 PM   #6 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
Not really that hard. Remove the front wheels, and slip your hand inbetween to get to the the bracket and two nuts holding it. I forget the size, but getting off might be difficult since it will be rusted to hell. PB first maybe 2-3 days in advance. Once it is off replacing is a easy.
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 10-13-2008, 03:46 PM   #7 (permalink)
RE: Replacing CAMRY LOWER CONTROL ARMS - Again, is this something I can tackle? Is this basic nuts and bolts? I intend to use all new aftermarket control arms, (no bushing replacement) Who has done this, how long does it take?
