n3rdifed:
Thanks for the advice, I am going to post there as well. However, I read that Toysrme is very much in favor of the 3VZ-FE (in his Camry) and knows tons of stuff about this engine....
dresev6:
I already did a lot of research and I am going to go Turbo. I also found out during research that the 3VZ-FE block, crank as well as the rods are pretty strong and that the only things you should strengthen if you want to turbo this engine are:
- the headgasket (e.g. one with copper layer or something)
- the headbolts
- the pistons
So now I am just looking for some companies that make these parts. I know they exist because I read that people had swapped in stronger parts. Unfortunately I have no idea where they bought their stuff.
