Camry 1995 Couple Horn Wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-13-2008, 09:31 PM   #1 (permalink)
View Monkey123's Photo Gallery
Angry Camry 1995 Couple Horn Wire
Okay, I'm hooked up a remoter starter from Design-Tech. Everything works fine except for the horn. The instalation diagram indicates wire is green/black. When I looked at the horn, the wire is green/white. I tried both of the wires but with no luck. Horn should sound when the remote start is press or a lock/unlock button is pressed. I need a horn wire. Thanks in advance for all the help.
Monkies123
Monkey123 is offline   Reply With Quote
Old 10-13-2008, 09:46 PM   #2 (permalink)
View JamesT1's Photo Gallery
I had the same problem - tried both with no luck. In the end I decided I liked it better without the horn sounding (draws less attention and less annoying).
http://bespokeauto.blogspot
1996 Camry LE Sedan 1MZFE
JamesT1 is offline   Reply With Quote
