Are you sure he didn't say oil was leaking in around the spark plug, rather than coolant. That would be more common and wouldn't take a new head gasket to fix. If that's the case, you can try retorqueing the 4 30MM spark plug tube nuts that are exposed when the spark plugs wires are removed, to 17 foot lbs in 3 even passes. Many times that cures the oil around the spark plug problem. If that doesn't cure the oil leaking in, then you will have to reseal the spark plug tubes. Resealing them is still a much easier and cheaper job than replacing a head gasket. This is all assuming that the problem is oil and not coolant leaking in around that plug.
Mike
