Recent service done - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2008, 04:36 PM   #1 (permalink)
View Pkim87's Photo Gallery
Recent service done
Hey guys I have a 97 camry i4 and just had my car serviced at an independent shop. I got my oil changed, oem front pads and rotors replaced, front brakes realigned, 4 new toyo spectrum tires, drain and fill transmission fluid, replaced right rear outer C.V boot, replaced engine valve cover gasket, replaced flexible pipe for the exhaust system, replaced air filter. The total was $1130 does that sound about right? Thanks
Pkim87 is offline   Reply With Quote
Old 10-15-2008, 05:20 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I've never hear of aligning front brakes.......And the rear wheels don't have CV boots.
You need to give a breakdown of what each thing costs
5 Lug Corolla WHAT?
Old 10-15-2008, 05:31 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Heh...you either just got ripped off, or they explained something to you wrong, because just like ASG stated, there are no boots on the rear and Ive also never heard of 'aligning the brakes'.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 10-15-2008, 06:05 PM   #4 (permalink)
This is what it says on the paperwork. (For the C.V boot I read it wrong the right front was replaced)
1. Oil Change- $19.35
2. Front brake pads- $65.87
3. 2 Rotors- $68
4. 4 Toyo Spectrum tires- $307.80
5. boot kit- $29
6. valve cover gasket- $12.28
7. Air Filter- $14.90
As for labor
1. Trans fluid change- $75
2. Reline front brakes replace rotors and pads, lube calipers and pistons- $85
3. Replace 4 tires and balance- $60
4. Replace flexible pipe- $120
5. Replace R/F outer C.V boot- $140
6. Replace engine valve cover gasket- $56
Old 10-15-2008, 06:14 PM   #5 (permalink)
Ok, that doesn't seem to bad. Only 2 things I'd say was a little high is the labor on the CV Boot and the trans fluid change. But honestly, everything looks fine, so I wouldn't worry.
5 Lug Corolla WHAT?
Old 10-15-2008, 06:16 PM   #6 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
maybe they mean "resurface" the rotors, not "realign"?
prolly wouldnt go back to that shop if it were me though
prices seem reasonable however - DIY woulda saved u a bunch of money, i couldnt imagine paying someone nearly $60 to replace the VCG after ive done it myself
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 10-16-2008, 12:45 AM   #7 (permalink)
View toyomoho's Photo Gallery
Overall OK, looks reasonable for the work done.
Old 10-16-2008, 01:03 AM   #8 (permalink)
Do not buy from
View Zviator's Photo Gallery
Half of the cost went into new tires and brakes, no wonder ...
Zviator is offline   Reply With Quote
Old 10-16-2008, 01:08 AM   #9 (permalink)
View importcar's Photo Gallery
Not bad at all. I've seen Sears charge a lady $45 for an oil change, top off fluids, and new wiper blades.
2001 Camry LE 5S-FE
importcar is offline   Reply With Quote
