How long from the first symptom to the last? Seconds? Days? Months?
NEO's point about the wires between the body and door are especially valid for the windows and locks. However, the lights are much more likely to be a fuse. I'm not familiar with the 220 SEi but the 5SFE has two cabin fuses that can cause this. Mine was a 10 amp fuse behind the coin door. It also shut down the cooling fans. I understand that there is a second fuse kind of hidden behind the steering wheel area. I've never tried to find this one. There was another thread that identified it pretty well. If you think it might apply to the 220 SEi you might do a search. I'm pretty sure that it was in this forum, this year.
Sounds like two problems.
Kep
