1997 Toyota Camry LE Battery - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2008, 03:03 PM   #1 (permalink)
View camry244's Photo Gallery
Hi, yesterday my 1997 Toyota Camry LE's battery died and I got it jump started. I drove it home and this morning the car did not start as the battery is dead once again. I've checked the acid level inside the battery and it seems to be fine. Is it time for a new battery?
camry244 is offline   Reply With Quote
Old 10-18-2008, 03:24 PM   #2 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
Are you hearing multiple clicks when you turn the ignition?
If yes, then it is time for a new battery.
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 10-18-2008, 03:28 PM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862610
View BamZipPow's Photo Gallery
Could be a few things wrong.
Bad alternator
Bad ground
Bad starter
Bad battery
Git the battery checked before replacing it. Were there any symptoms prior to the battery dying? Like the starter not turning over (bad starter contacts). Dim lights (bad alternator brushes).
BamZipPow is online now   Reply With Quote
Old 10-18-2008, 03:32 PM   #4 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $907727
iTrader Score: 59 reviews
AutoZone will check your battery for free, and even install a new one (not for free)
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 10-18-2008, 03:33 PM   #5 (permalink)
BamZipPow's Avatar
Do they have AZ in Canada?
Old 10-18-2008, 04:03 PM   #6 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
^ Good Point. I think Candian Tire may check it for free.
How old is your Battery?
5 Lug Corolla WHAT?
Old 10-18-2008, 04:49 PM   #7 (permalink)
I don't hear any clicks when turning over the car and there was no prior problems except one time I left the door open overnight and the battery got drained but I jump started it and it ran fine until yesterday. The battery is original which is 11 years old. I suspecting it's the battery. And if I open the door I can see the open door warning on the dash that is very dim and the power locks sound a lot weaker than normal.
Old 10-18-2008, 06:49 PM   #8 (permalink)
11 years old???!!?!?! HOLY CRAP! My 1st Camry and my dad's had the battery last 8 years, and I thought that was crazy....
Yeah, your battery is dead for certain at that age. That is MUCH longer then average. Pop in a new battery and all should be good.
5 Lug Corolla WHAT?
Old 10-18-2008, 10:20 PM   #9 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
That's almost 3 time the lifespan of a normal battery, guy!
JEEESH!
ACCIDENT...
Thanks
Old 10-18-2008, 11:03 PM   #10 (permalink)
Haha, yeah I was suspecting the battery was the problem also but I just wanted another opinion. If I were to purchase a new battery which brand should I go for and where can I buy it? I'm located in Toronto, Ontario.
Old 10-18-2008, 11:16 PM   #11 (permalink)
Funny enough, MY battery is dead and I need a new one. I'm personally going with a Toyota one, BUT they are a lot cheaper here in the states. I'm not an expert on battery brands by any means.
5 Lug Corolla WHAT?
Old 10-18-2008, 11:16 PM   #12 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
If your car isn't loaded with a high power stereo system, a standard replacement battery will be fine.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 10-19-2008, 02:44 AM   #13 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
Wow, eleven years. I was shocked.
It must be the battery.
It's time for a new battery for me too, though it is hard to give up my current one, no problems what so ever, unlike the previous one, which would die all the time, and wouldnt turn over especially in the winter months. But, the current one is leaking white battery acid through the mounting bracket area, not even at the terminals. My current is a NASCAR selects battery, so that would mean its an interstate battery, right?
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 10-20-2008, 02:24 PM   #14 (permalink)
Gameroom cash: $303255
A simple test to determine if the battery is at fault is to try to jump start the car. Have you tried that? If it starts, the battery is weak/dead. Then you still have to determine if it's the battery itself or the charging system (alternator or loose alternator belt). If still no start when attemtping to jump start it, you then have to check all the connections at the battery and the starter. If those are good, then you may have a starter issue.
Just out of curiosity, what brand is your original OEM battery and was your car made in Japan?
Mike
Mike Gerber is online now   Reply With Quote
Old 08-15-2009, 05:57 PM   #15 (permalink)
tekno9000's Avatar
View tekno9000's Photo Gallery
My battery is dying. I need to change it. I have an Interstate battery on my car. Mine is Canadian make. Before I buy a new battery, just like to know what is the OEM battery?
Thanks,
Tekno 9000
1995 Camry LE 5SFE 4 Cyl.
tekno9000 is offline   Reply With Quote
