Huge Oil Consumption - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2008, 11:19 AM   #1 (permalink)
Proud TN Member
View Crlnd132's Photo Gallery
3rd Generation Huge Oil Consumption
Hi, mine's a 92 5sfe camry 102.000 miles and with a huge oil usage. Like a quarter every 200 miles. No big smoking or leaks. It smokes on cold mornings until it gets warm.
I released the hose from the throttle body and i can see smoke coming out of there on desceleration and maybe a little oil but not sure.
It consumes more when i drive hard. If i drive like a granny the oil stays longer.
What could this be?
Crlnd132 is offline   Reply With Quote
Old 10-19-2008, 11:37 AM   #2 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
hmm
Probably valve stem seals.
frenum49 is offline   Reply With Quote
Old 10-19-2008, 12:49 PM   #3 (permalink)
just a nobody
Check, valve seals. And your PCV valve also.
But you may want to do a compression test and leak down test also, to see how you engine is doing. From your description, there may also be some blow-by. Probably won't know if the oil rings are stuck or not but nevertheless, more information on the health of your engine is always better than not enough.
N.E.O.
Old 10-20-2008, 12:46 PM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
what is the oil weight you are using?
Old 10-20-2008, 03:32 PM   #5 (permalink)
Gameroom cash: $303255
102,000 miles is not that many for a 5SFE engine, if the oil changes have been done on a timely basis. If it is using oil my bet is valve seals rather, than piston rings. Before doing anything else, remove the PCV valve and see if the check ball inside of it is moving freely. Just shake it. Do you hear it moving around?. If not, try cleaning it with brake cleaner or just replace the valve with a new one. They are not that expensive. If the check ball is moving freely, then your problem is elsewhere.
Mike
Mike Gerber is online now   Reply With Quote
Old 10-29-2008, 10:04 AM   #6 (permalink)
Proud TN Member
3rd Generation
The pcv valve is new. compression is at 180 per cylinder. I use 20w50 oil. If it's blow by, how do i fix it? with the engine running if i remove the hose from the throttle body (the one that goes connected to the valvecover) i can see smoke and oil ocassionally.
Old 10-29-2008, 10:20 AM   #7 (permalink)
just a nobody
Remove the valve cover to see how it is inside the engine, which would be indication of whether the rings are sticking or not. Too much blow by would usually require new rings and depending on the bores may be more. Do a leak down test too.
N.E.O.
Old 10-29-2008, 11:16 AM   #8 (permalink)
View llcoolpass's Photo Gallery
hahaha 20w50 hahaha
your engine is f-ed, and you know it, but if you're really interested in fixing it, lets talk then...
180 psi ... is that on a cold engine with 10w30 ? your oil is at least leaking from the valve stems in this case and causing your compression reading to go up. 180 psi is high
1993 Lexus ES 300 [completely stock] -- 5-speed Manual V-6 3VZ-FE -- Curb Weight 3,570 lbs; Mileage 152,000 -- 0-60mph http://www.youtube.com/watch?v=ygwUh1MZRLM
llcoolpass is offline   Reply With Quote
