1997 V6 clutch replacement - how much? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2008, 06:35 PM   #1 (permalink)
View kenratboy's Photo Gallery
4th Generation 1997 V6 clutch replacement - how much?
I know I asked this question a while back, but not sure I got an answer.
My car has ~125k miles and the original clutch, and its finally starting to get bad. Slipping, especially in 5th gear (put your foot down, engines spins up to about 4500 RPMs, then it starts to grab and settles at about 3000 RPMs).
In your experience, what should I expect to pay a shop to do the job? What parts or work is there (I know there are a few pieces as part of a kit, any other work)?
I heard somewhere north of $500, is that accurate?
Thanks!
1997 Camry CE V6 5-speed!
Mods: Whiteline rear sway bar & nice tires.
2009 RAV4 Limited V6 4WD
Mods: nothing you would care about.
kenratboy is offline   Reply With Quote
Old 10-19-2008, 07:08 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
yup...well north of 500 just for the labor, probably around there for an outside shop, probably closer to 700-800 for a dealership
then the final price will depend on what parts you want for your clutch- oem, aftermarket, performance, etc,
HaHa
Old 10-19-2008, 07:17 PM   #3 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
Thanks!
go to your local toyota dealership ask them for the clutch kit for your car should include clutch & pressure plate. so i'd say $2-300 for the kit (est) and labor is gonna be a pretty penny because gettin the clutch out of a v6 5spd aint easy. i'd say $500 is a good estimation.
the clutch kit should be something like this
http://www.exedyusa.com/oe/16062
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 10-19-2008, 07:17 PM   #4 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Clutch kits come with everything needed, but a shop will highly recommend (as will I) seals and possibly getting your flywheel machined, if feasible.
The seals are maybe 10 bucks.
Flywheel being machined was about 50 bucks when I had it done.
If your flywheel needs replacing, I think they are pretty expensive.
Chris Crash is online now   Reply With Quote
Old 10-20-2008, 01:36 AM   #5 (permalink)
Thanks guys.
For the flywheel, is it common it needs to be resurfaced? Why does it get messed up?
Old 10-20-2008, 05:58 AM   #6 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
to do the clutch in a V6, essentially involves dropping the subframe, that alone would cost a few hundred of it all, I'd say about $1000 job conservatively.
as far as the flywheel, fairly cheap to replaced if you are uneasy about resurfacing
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 10-20-2008, 07:48 AM   #7 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i did a DIY gen 3, 4cyl and gen4 v6 clutch swap with out droppping the subframe, enough room to separate tranny and slide it to the side to get the clutch work done.
i even did a tranny replacement on my 4cyl manual transmission with out dropping the subframe, just lucky, turn the larger side toward front, and then rotate sideway and drop to floor slowly.
i did asked the shop 2 or 3 years ago on a 4cyl clutch before i decided to do it myself, and the shop said around $500 part and labor as well.
looking at DIY 10 to 20 labor hours, clutch kit, rear main seal, cv axle seals around $200 OEM parts.
main reason to resurface flywheel friction area may become uneven due to friction wear from clutch disc, if you dont resurface the worn flywheel when installing new clutch, the clutch disc may wear out prematurely.
bronzemaxell is offline   Reply With Quote
Old 10-20-2008, 11:50 AM   #8 (permalink)
$1000? I'll just pay a homeless man to torch the thing :p
Old 10-21-2008, 05:13 PM   #9 (permalink)
Bdub215's Avatar
Thanks guys.
technically all you need to do is get some rough sandpaper and scuff up the flywheel and your good to go.
