Need some help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2008, 08:16 AM   #1 (permalink)
View toyotarocks21's Photo Gallery
Need some help
Hi
Ok I've got a 2003 Camry 4 cyl with 76000 miles I was driving it home yesterday it started running rough and then it died now I can't get it started
it won't even turn over ( I think it's locked up ) I have two codes ( P0012 "A" Camshaft position timing retarded ) (P0335 Crankshaft position sensor "A" circuit this one is just a pending code) Can anyone help with this
Thanks
toyotarocks21 is offline   Reply With Quote
Old 10-20-2008, 08:27 AM   #2 (permalink)
View unkit's Photo Gallery
Dejavu.... i just described the same problem. Did you have ur timing belt replaced recently too?
I did some research, and it seems that timing belts can slip... but this is usually when they are old.
unkit is offline   Reply With Quote
Old 10-20-2008, 08:34 AM   #3 (permalink)
I don't think the timing belt has ever been replaced. do you think that is the prob??
Old 10-20-2008, 08:40 AM   #4 (permalink)
just a nobody
03', Don't they have timing chain? I would suggest looking at the current code for the cam, may be the VVT-i actuator is stuck.
N.E.O.
Old 10-20-2008, 10:36 AM   #5 (permalink)
will do thank you
