Both of those items could affect you. Verify that the sensors are OK and, if they are then figure out why they are indicating a problem.
The camshaft position sensor is what the ECU uses to establish where the valves are to coordinate fuel and spark.
The air/fuel sensor heator heats up the O2 sensor (I think that's the same as the air/fuel sensor) when the car is cold and heating up. This would cause more problems during warm up. When the heater fails I'm pretty sure that you will have to replace the whole O2 sensor.
Kep
