Spark-Plug tube removal tip... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2008, 08:35 PM   #1 (permalink)
View barthmonster's Photo Gallery
Discovered this tonight, who needs a $70 tool !!
SPARK-PLUG TUBE REMOVAL TIP !!:
* Remove valve-cover
* Insert a nut from the spark-plug tube on the tube to be removed but
install the nut flat-side up.
* Insert another nut from a different spark-plug tube on the tube to be
removed flat side down (flat side to flat side)
* tighten the two nuts towards eath other (double-nut technique) until tight
using channel-locks or whatever.
* using an open-end 30mm wrench or channel-locks on the lower of these
two nuts, remove the spark-plug tube.
hope this helps someone out there...
barthmonster is offline   Reply With Quote
Old 10-20-2008, 09:42 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $198580
View xtremeskier97's Photo Gallery
Why would you do this? Is there a seal down there or something that needs to be replaced?
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
