rear speakers questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2008, 08:35 PM   #1 (permalink)
View zwfly's Photo Gallery
3rd Generation rear speakers questions
My car is 94 camry LE 5s-fe
question 1:
The stock rear speaker is 6ohm 15w, can i change it to 4 ohm ( most popular nowadays) ?
question 2:
The stock rear speaker looks like fish, can i simply use a molding tape or buy an adapter from ebay?
zwfly is offline   Reply With Quote
Old 10-20-2008, 08:49 PM   #2 (permalink)
View scoprius's Photo Gallery
You could use those adapter plates but they tend to cause rattling on lower notes, or at higher volumes. I personally used a punch and hammer to mark where the four mounting holes were on my speakers in the metal of the rear deck, then drilled them out from inside the truck with my cordless drill. I also applied a layer of dynamat around the edge of where the speakers would be sitting on the interior side to eliminate some of the rattling back decks tend to have.
scoprius is offline   Reply With Quote
Old 10-20-2008, 08:57 PM   #3 (permalink)
can i use silicon glue?
Old 10-20-2008, 09:15 PM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Those adapters will work just fine. I used them in my 96. Just put a bead of silicone sealant between the adapters and the speakers. You'll need to trim the adapters a bit for them to clear a small ridge on the rear deck's surface. Then use thick foam tape(or a few layers of the thin stuff) between the adapter, and deck surface to seal to up. That will keep the adapters from rattling, and dynamat will keep the rear deck from rattling.
Another good thing about those adapters is that they raise the speakers a bit, so the larger magnets of after market speakers don't hang so low in the trunk.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 10-20-2008, 09:56 PM   #5 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
THOSE ADAPTERS WILL NOT WORK!
Trust me, I know, I just took them out of my car todat and making my own MDF ones. I have to cut and modify those ebay POS ones. They are not even close to working well.
5 Lug Corolla WHAT?
Old 10-20-2008, 09:59 PM   #6 (permalink)
uibalnme's Avatar
Well, sorry they don't work for you. I've had mine in for 2 years, with no problems of any kind. They've held up perfectly even with 350watt 6x9's pounding away daily.
Old 10-20-2008, 10:17 PM   #7 (permalink)
Just cause they work, does not make them good. And depending on the specker you have, you may have to even modify the inside part of the crappy mount.
5 Lug Corolla WHAT?
Old 10-20-2008, 10:39 PM   #8 (permalink)
uibalnme's Avatar
I've got Pioneer TS-D901P 350watt 6x9's. Perfect fit into the adapters. Before those I had a set of Blaupunkt 6x9's, again perfect fit into the adapters. I just had to trim a bit off the outer edge of the adapters for them to sit flat. That's all. It wasn't a big deal, and besides, if they're sealed properly, they will perform just as well as MDF adapters.
Old 10-20-2008, 11:12 PM   #9 (permalink)
3rd Generation
how good do you expect?
Since i am a newbie here, I found the bass improved a lot.
Also, i installed a sony x-plod one. It may touch the trunk spring, how can i know if it touch when i close the trunk, open the rear seat?
Old 10-20-2008, 11:15 PM   #10 (permalink)
MDF :
=Main Distribution Frame ?
Old 10-20-2008, 11:22 PM   #11 (permalink)
uibalnme's Avatar
MDF = medium density fiber-board. It's the stuff speaker boxes are made of.
1) Like I've said, 2 years, and no problems. If that's not good, tell what is.
2) Any quality after market speakers will improve bass response.
3) My Pioneers have HUGE magnets, and they don't touch anything. Yeah, with the trunk closed, just crawl in after you fold the seats down, and look at the clearance. However, I'm sure they will not touch the springs.
Old 10-21-2008, 12:35 AM   #12 (permalink)
thanks, dude. your info is very HELPFUL
Old 10-21-2008, 12:43 AM   #13 (permalink)
uibalnme's Avatar
No problem. Have fun with the system upgrade. When I did mine, it made my car twice as fun to drive.
Cheers!
