gen 4.5 conversion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2008, 04:01 AM   #1 (permalink)
Blckdout97camry
View jakemm52's Photo Gallery
4th Generation gen 4.5 conversion
So i did the conversion bout 5 months ago and i still havent hooked up the 9005 headlight.
So acouple days ago i got the harness and pigtailed it to the halos but it keeps blowing a fuse.
Has anyone figure out how to make both the headlights work on a gen 4?
I need help cuz i really want to have both them on put not if its gonna keep blowing fuses.
jakemm52 is offline   Reply With Quote
Old 10-21-2008, 10:12 AM   #2 (permalink)
View 07civiclx's Photo Gallery
i made a harness dude!
how did u get the headlights to fit? i couldnt cause of asteal bar in the way!!!1
i built a custom harness, took me a few hours and over 60 bux, but it worked PERFECTLY
then i went to bolt em on, and the anzo headlights DONT FIT!!!!
WTF! the anzo ones said 98 camry, but are designed for the 4.5 gens!
07civiclx is offline   Reply With Quote
Old 10-21-2008, 01:27 PM   #3 (permalink)
wtftoy's Avatar
View wtftoy's Photo Gallery
Yep, there's a DIY on this conversion. You have to cut the steel bar and etc... I'll try to find DIY.
edit:
The How To: 00-01 Headlight Conversion W/Minimal Parts - NO 56k!! NO 56k!!
1998CamryLEV6
Tokicos,Eibachs,TrdRSB,Intake,Jim'sTorqueRod.
wtftoy is offline   Reply With Quote
Old 10-21-2008, 01:41 PM   #4 (permalink)
i already returned em, but for someone who needs it
i have a wire harness, ready to go!
that means 9005 and 9006 bulbs will light when u hit the high beams!!!!!
i think i should sell it to someone, cause id rather do the hid retrofit with the clear lens now!
Old 10-21-2008, 10:27 PM   #5 (permalink)
Blckdout97camry
whatd you connect your harness to. Because i think the reason i keep blowing fuses is because i pigtailed them into the halos and not the headlights. Do you guys kno if i pigtail them into my headlights if it will dim my headlights.
Old 10-22-2008, 03:18 PM   #6 (permalink)
no dude, i built a harness, with 3 spst (had to use spdt but it still worked) relays and a bunch of wire and connectors lol
worked great, except i then found out the headlights DIDNT fit and returned them... so its just sitting around collecting dust, and now i find out they CAN fit im so mad!
Old 10-26-2008, 12:18 AM   #7 (permalink)
Blckdout97camry
i figured it out i just put in a relay it works like a dream
Old 11-03-2008, 01:46 PM   #8 (permalink)
a relay?
or 3 relays?
