Cannot remove distributor ?
Okay here is probably an ignorant question, but its driving me nuts.
1993 Camry LE, 2.2 4cyl, automatic
I need to remove the dizzy in order to get at the far corner head bolt (I am removing head to replace blown head gasket). Manual says, remove hold down bolt (one) and remove dizzy. I remove hold down bolt, that thing is NOT coming out of there, nor does it look like it will come out. I cannot find any other retention. It does appear that the knuckle joint (for lack of better word) which engages the camshaft needs to be removed in order to extract the dizzy. And it looks as if it has a dowel pin retaining it. However I don't want to trash anything, obviously. Oh and also the distributor housing will not turn whatsoever, now the hold down bolt is in a slot as I'm used to seeing in my Hondas (and about every other car), to allow rotation of the dizzy for timing adjustment, however I'm yet again puzzled by the fact that it won't rotate....
This car also has the WEIRDEST distributor design I've ever seen...Aside from the extreme pain in even getting the distributor cap off, there is no visible way to remove the rotor, everything is covered/concealed by a plastic 'do not remove' cover.... This is my first time wrenching this area of the engine since I inherited it from my father.
I really need help getting that distributor out !
thanks,
-z-
