front pipe & o2 Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2008, 02:04 PM   #1 (permalink)
View Robscamry's Photo Gallery
Is it easy to change out a front pipe for the unexperinced person.
Also when replaceing a o2 sesor, is it plug and play or do you have to reset the computer
Robscamry is offline   Reply With Quote
Old 10-21-2008, 02:47 PM   #2 (permalink)
just a nobody
Usually is a matter of taking of the nuts and bolts, but make sure you spray it down with some type of penetrant first.
Unless you have a CEL, replacing an O2 is kind of plug and play. Again, be careful in some cases the sensor may get stuck, most often not but can't say. Even if you have a CEL, just disconnect the battery will clear that out.
N.E.O.
