5s-fe timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2008, 08:50 PM   #1 (permalink)
View 99545's Photo Gallery
5s-fe timing
i just replaced my distributor (long story) anyways the timing is a little more retarded now, i tried to line it up in the same position as the old one. i need to know which way to turn it to increase the timing. please don't tell me the timing is not adjustable, if i wanted to hear that answer i would read the hanes manual. it can be done so clockwise or counterclockwise? Thanks
on a side note any reason the oil pressure would be running 10 psi higher than usual after the distributor change? thanks guys!
03 Chevy Silverado 5.3 4x4, tires, body lift, Custom tuning by me
09 Corolla S black
95 Camry 5sfe RIP
all obsessively maintenanced by me
99545 is offline   Reply With Quote
Old 10-21-2008, 09:01 PM   #2 (permalink)
question answered man after all the reading i couldn't find it till a posted here
http://www.toyotacelicaonline.com/timing.htm
but anyone have any ideas on the oil pressure being higher?
09 Corolla S black
95 Camry 5sfe RIP
Old 10-21-2008, 09:30 PM   #3 (permalink)
just a nobody
You got an oil pressure gauge hook up on the car? Did you check both pressure under the same conditions?
N.E.O.
Old 10-21-2008, 09:37 PM   #4 (permalink)
yes its a autometer cobalt mechanical one. and yes same conditions. i drive 60+ miles a day so i have a good feel for what normal pressure are like
09 Corolla S black
95 Camry 5sfe RIP
Old 10-21-2008, 10:04 PM   #5 (permalink)
just a nobody
Maybe the rpm is slightly higher? That would cause an increase in oil pump output, other than that, can't really think of any relationship between oil pressure and distributor replacement.
N.E.O.
