How do I take the logo OFF - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2008, 09:55 PM   #1 (permalink)
muminiasty's Avatar
View muminiasty's Photo Gallery
Hey guys I was wondering if there is a clean and safe way of taking toyota word and LE from the back of my camry? Those look little bit old already. I don't want to rip off the paint with those. Is there a way?
muminiasty is offline   Reply With Quote
Old 10-24-2008, 09:59 PM   #2 (permalink)
NBBADTOYS
View keisuke's Photo Gallery
razor blade and slow going and a bit of heat ( i used blow dryer and hot water - not at the same time)
1997 Toyota Camry XLE V6- 308500 and counting
keisuke is offline   Reply With Quote
Old 10-25-2008, 12:46 AM   #3 (permalink)
Do not buy from
View Zviator's Photo Gallery
Place a thin towel between the blade and the trunk surface when u do it.
Zviator is offline   Reply With Quote
Old 10-25-2008, 12:53 AM   #4 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
Use the search option.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 10-25-2008, 01:37 AM   #5 (permalink)
View tran.man48's Photo Gallery
yours may or may not have pegs... mine did. Pegs leave holes behind that you'll have to fill.
Originally Posted by Zembonez View Post
Nothing is impossible with enough money and beer.
tran.man48 is offline   Reply With Quote
Old 10-25-2008, 01:59 AM   #6 (permalink)
View angel_rolla's Photo Gallery
use a dental floss. then adhesive remover.
angel_rolla is offline   Reply With Quote
Old 10-25-2008, 04:55 AM   #7 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $907727
iTrader Score: 59 reviews
80lbs test fishing line works great. What model year u removing these from?
Gen 3's are usually pegged, Gen 3.5 and beyond aren't, except the sombaro in the middle of the trunk, and the letters on the center panel.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 10-25-2008, 07:10 AM   #8 (permalink)
muminiasty's Avatar
it is 97 camry and when I look from the side it seems like they only stick on some adhesive. Or do they have holes behind as well? Thanks for ur replies
Old 10-25-2008, 09:41 AM   #9 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862310
View BamZipPow's Photo Gallery
97 Camry only has pegs on the center logo. The Toyota, Camry, LE/XLE are just stickies...use the floss and some GooGone to remove the adhesive.
BamZipPow is online now   Reply With Quote
Old 10-25-2008, 09:54 AM   #10 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
Another vote for fishing line. That's what I used and it worked great. Heat helps. I did mine when it was 100 degrees outside and I let the car bake in the sun for a couple of hours before hand. Didn't need a heat gun or hair dryer that way.
If you use a heat gun, be careful. I recall seeing a thread awhile back where somebody accidentally melted their tail light with a heat gun while trying to heat up their badges for removal. A hair dryer is much safer and should produce adequate heat.
eddie926 is offline   Reply With Quote
Old 10-25-2008, 09:57 AM   #11 (permalink)
muminiasty's Avatar
THe logo is almost pealing off by itself. It has two holes under i believe. Is there a place where I can buy Toyota logos to replace it . Maybe in different color??? Thanks guys. I will definitely go with floss.
Old 10-25-2008, 10:24 AM   #12 (permalink)
'95 Camry V6 XLE
You can find a lot of badging on eBay. Some new, some used.
Old 10-25-2008, 10:39 AM   #13 (permalink)
muminiasty's Avatar
will 2007 or 8 camry fit my 97 camry on the trunk
Old 10-25-2008, 10:56 AM   #14 (permalink)
Super Moderator
eyeball96's Avatar
I don't believe the 07-08 sombaros will fit 97. Different Gens seem to have different peg holes on the Sombaros, but if u trim off the pegs they will ...but all the other emblems will as they just stick on
98 Honda CRV
08 GMC Crew
Old 10-25-2008, 11:02 AM   #15 (permalink)
muminiasty's Avatar
I took the everything off now I have all that adhesive left. I just want to make sure won't googone take any of the paint off??
