Temperature Anomaly: 92 Camry V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2008, 07:09 PM   #1 (permalink)
View Rob_0126's Photo Gallery
My temperature guage goes up to midway, past it a bit, then back down at times. Sometimes it doesn't. On an older vehicle, Id say the coolant thermostat is sticking, but it is practically a brand new toyota brand thermostat months ago. I put it in by the book. Didn't start this until months after the new t-stat.
Would a sensor do this? Or is it something else? (176,000 miles, rebuilt 1,500 ago)
Rob_0126 is offline   Reply With Quote
Old 10-25-2008, 07:36 PM   #2 (permalink)
just a nobody
Sounds like it is doing its job, unless you have another gauge to compare it with it is difficult to say whether you are actually having problem or not. When the engine heats up the temperature of course will go up, but then when the cooling fan goes into high speed circulating the air and cool down the coolant it will drop back down. Road condition and outside temperature will also affect the temp of the engine and hence the gauge reading.
Did you clean the radiator when you have the engine rebuilt? Any particular reason why you are concern with the temp reading?
N.E.O.
Old 10-25-2008, 08:58 PM   #3 (permalink)
N.E.O.
it's never went this high, never over half way. It's just recently started this.
Old 10-25-2008, 09:10 PM   #4 (permalink)
just a nobody
If you want to verify if the gauge is functioning properly try 70th page of this link: http://www.camrystuff.com/manuals/Gen3/be.pdf
Also check to make sure the coolant level and the fan is functioning properly. If everything seems to operating, you may have to keep monitoring.
N.E.O.
Old 10-25-2008, 11:17 PM   #5 (permalink)
N.E.O.
MY suspicion is the cooling fan, because it goes full throttle at times. If I sit at a dead stop at idle, after a few minutes, the temp goes past half way a little, then back down quickly, and not at a specific amount of time to do so.
If I rev the car engine a little(1200 rpms), it will come back down after a brief pause.
Could any of these cause this:
Radiator fan switch
Coolant temp sensor
Power steering pump failing(so not giving fan enough pressure at idle?_
idk, this car is complex compared to the gm's ive messed with. As deep as I have gotten is the gm TBI. But im learning. Lots more sensors to check.
Old 10-25-2008, 11:39 PM   #6 (permalink)
just a nobody
Did you flush the radiator when you had the engine work done? What about the water pump, was that replaced?
The first two items both are possible, the P/S pump, I don't think so if the fan actually went to high speed. The sensors you can test to see if they are within the spec range relative to their resistance. However, both require having good coolant circulation, so whether the pump or radiator are doing their job would make a difference.
N.E.O.
Old 10-26-2008, 10:20 AM   #7 (permalink)
N.E.O.
I flushed the radiator myself after I bought the car. He said he replaced teh water pump, so it's new.
Old 10-26-2008, 10:49 AM   #8 (permalink)
just a nobody
Check for uneven temp across the radiator to see if there are cool spots, which would indicate restriction of flow. And test the sensors to see if they are within the spec range.
N.E.O.
Old 01-16-2012, 09:15 PM   #9 (permalink)
FNG
View GTcelica22's Photo Gallery
did you ever find the problem? i'm having this problem now.
GTcelica22 is offline   Reply With Quote
