forgot to give info - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2008, 10:15 PM   #1 (permalink)
conehead5887
View conehead5887's Photo Gallery
forgot to give info
my 94 camry is a v-6 1mzfe and i'm unable to get the code reader to work but the check engine light comes on only on my weekly trip to Olympia about 50 mile round trip,everone i've talked to says i have to much air now because of the cold air intake is there a way to up the fuel in runs killer above 3500 rpms. ant help would be appriciated. is there a way to read the codes through the check engine light if so how?
conehead5887 is offline   Reply With Quote
Old 10-28-2008, 12:08 AM   #2 (permalink)
No longer in use
View lgcongbach's Photo Gallery
3rd Generation
bring it to autozone to have the code read
lgcongbach is offline   Reply With Quote
Old 10-28-2008, 12:10 AM   #3 (permalink)
Do not buy from
View Zviator's Photo Gallery
First, post this on the other thread u made earlier.
Second, the check engine light only indicate that one of the sensors (many sensors) in the engine ran off. There are varied reasons to have this happens and the only way to know for sure is to have the computer hooked up to the ECU (i'm not taking about PC or Mac here).
But according to what u said, it's most likely the air sensor located on the front end of the air intake.
Zviator is offline   Reply With Quote
Old 10-28-2008, 04:16 PM   #4 (permalink)
View camry6's Photo Gallery
Canada Try this.
I installed a cold air intake on my '93 3mz-fe V-6 3 years ago. The engine management is a little less involved, but very similar. I've never had this issue. The stock ECU can compensate for the extra air-to a point of course. I gained extra performance from mine by turning the fuel pressure return regulator adjusting screw out a couple of turns. This may help if your fuel management is topping out. The fuel pressure return regulator is located on the left side of the engine (Right side when standing in front facing your car) it is the regulator on the end of the rear fuel rail, where the return fuel line connects. remove the opaque plastic cover and in here you will find a phillips head screw. back it out 2 or 3 turns and replace the plastic cover. Road test.
camry6 is offline   Reply With Quote
Old 10-28-2008, 07:02 PM   #5 (permalink)
conehead5887
return reg
i turned it out and noticed a small diff will be able to better tell on my next trip to olympia will this kill my mileage?
