Hello all, I had a major accident in my 99 camry 5 years ago. I was broadsided at the passenger rear quarter panel and I still can't get over when it was repaired the shop did not set the rear passenger wheel to factory specs. The rear passenger wheel sticks in ___ / ___ too much like negative camber, it should be like ___\ ___ positive camber as compared to the driver side rear wheel which sits ___ / ___ as it should. I can tell b/c I pay close attention to detail. Here is a pic maybe you can tell me how to adjust it so that it has its positive camber restored. The car does not drive different but it is very irritating to me although it is something so trivial. All replies on how to fix this will be greatly appreciated!
It;s 1 of 2 things. The wheel is out of alignment, or there is a bent suspension part. Is there a mechanic you trust that you can have take a look at it?
My riced out crapmobile Camry: http://www.cardomain.com/ride/228043...y-xle-sedan-4d '96 Camry: 2MZ Supercharged.....
5 Lug Corolla WHAT?
Go to a good alignment shop, it might be expensive but its worth it. Ever since I changed my suspension a month or so ago, and my chamber is fu*ked. Can't align it yet until I can replace the strut mounts. They some crappy ebay brand, so getting them from the dealership this time. Front strut mount is like $75 each, bearing is around $40; that's for one corner...........expensive!
If you can see the camber is in the wrong direction, chances are something's bent. Probably the strut. Camber is, for the most part, not adjustable. There is a little bit of play in the fit of the bolts holding things together, but I'd be surprised if it's enough to give 1 degree of adjustment if it were pushed in one direction. The adjusting bolts that can be purchased typically give a few degrees of adjustability; not enough that you'd be able to see it.
By the way, if the top of the wheel is tilted outwards away from the car, that's positive camber. Here's some negative camber for ya... Link
I have no good mechanics I know of I have to search for a good one. I hope it's not a bent suspension part it was expensive to fix after the accident I think they may have cut corners...
When I was 16 I got broadsided and my mother paid almost $9,000 to repair it. Insurance fucked me over. I'm 21 now and lately the positive camber has just been annoying the shit out of me but no one else can barely tell that the wheel is like that. After reading what the last few forum members have been telling me, I think i'll just get coilovers and a camber kit some time in the future. The car doesn't drive bad in any way and the tires still wear evenly after all these years. I feel it is a damaged strut that they did not replace but charged us for it and yes the frame was bent. The car does not crabwalk and I can let the steering wheel go at any speed and the car goes straight for at least 500 feet. I have to get a job first... Thanks for all the replies guys I really appreciate it!!
It's hard to explain but there is a bent suspension component and I think the strut may be bent also. What would be a better option coilovers, or tokico struts and springs? Also i'll have to go to the junkyard to get a 99+ suspension component( I don'y know what to call it) I'll also get a camber kit after installing the struts or coilovers...
Could be any of those parts though, the spindle or hub itself can be somewhat bent, just have a mechanic look at it and diagnose it before choose new struts and springs.
But, as far as strut and springs go, if you are into driving with better handling and don't mind the stiffness, then coilovers are definitely probably the better way to go, over spend about $500 or more in struts/springs anyways.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
I am a noob and still learning about Camry/cars are you guys talking about the rear tires not lining up?
__________________ Problems I've fixed with the help of this forum: The brakes squeak annoyingly. Problems I still need help with: Driver lock button locks all doors BUT driver's door. Driver electric seat buttons and gas door switch don't work.
