Changing Distributor Housing: 3VZFE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2008, 08:06 PM   #1 (permalink)
View Rob_0126's Photo Gallery
I know it has to be simple. But I have to make sure their isn't a 'gotcha' with toyotas.
I pulled a new one off the pick n pull yard a few days ago. Looks straightforward: Just pop the cap off, then rotor, then the 2 bolts holding the housing on the block. Then just pull.
Now If I match up the alignment exact as the one I pulled, is that just about it?
Rob_0126 is offline   Reply With Quote
Old 10-30-2008, 06:05 PM   #2 (permalink)
anyone?
Old 10-30-2008, 08:21 PM   #3 (permalink)
engineer in training
Gameroom cash: $145055
It is that simple, the cam notch will only go on one way so there is no way to put it on the wrong way. Just remember to set your timing afterward!
Old 10-30-2008, 08:59 PM   #4 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
^Yep.. .exactly what he said... Once you've done it, you could do it again with your eyes closed! (at least that's how I felt, )
BlueFusion6851 is offline   Reply With Quote
Old 10-30-2008, 09:06 PM   #5 (permalink)
Ok good. Was making sure I didn't have to turn the crankshaft to TDC and such, where I have read that somewheres.
Appreciate it!
Robert
Old 11-01-2008, 06:48 PM   #6 (permalink)
Update:
Put the newer distributor housing on, car seems to run a lot better on part throttle.
The toyota dealership was right, it was leaking oil inside the housing really bad.
The cap leds were corroded fairly bad.
Like I said, step in throttle improved a whole lot.
