00 Camry Manual Transmission Swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2008, 10:30 PM   #1 (permalink)
00' Camry LE
Karman's Avatar
View Karman's Photo Gallery
Hey guys,
I'm looking to do a transmission swap for my car. I have a 2000 Camry LE I4 2.2L with a automatic transmission. I would like to put in a Manual transmission since my the current transmission in my car is about to die day now. I've always wanted one, and I figure now's my opportunity since i will have to change the transmission either way when it dies any day now.
So Does anyone know where I can find one and if its possible to do this swap? Also how much money am I looking at here? Would I also have to change my engine to support a Manual transmission?
Please let me know!
Thanks!
Karman is offline   Reply With Quote
Old 11-02-2008, 04:03 PM   #2 (permalink)
00' Camry LE
Karman's Avatar
Bump....Anybody help me?
Old 11-02-2008, 04:07 PM   #3 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search
RichieRichJP is offline   Reply With Quote
Old 11-02-2008, 08:34 PM   #4 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
It's very possible, but it is a lot of work. Just off the top of my head, here are the things I can think of that you need.
Manual transmission
shift linkage
shifter assembly
clutch pedal assembly
clutch master cylinder
clutch hydraulic lines
clutch slave cylinder
clutch kit (throw-out bearing, pressure plate, actual clutch disc)
Flywheel for manual transmission
transmission mounts
front axles are probably different (left and right)
starter might be different
Toyota Repair Manual
I'm sure there are more miscellaneous parts. Probably the easiest (and likely most cost effective) thing would be to get a donor car at a salvage yard as those miscellaneous parts are the pain. Look in your yellow pages and see what your local salvage yards have.
One thing I will mention is that while Camry are very common cars, Camrys with manual transmissions are not. It might take a some searching to locate one.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 11-02-2008, 09:14 PM   #5 (permalink)
00' Camry LE
Karman's Avatar
Manual transmission
shift linkage
shifter assembly
transmission mounts
Wow man that does sound like a lot of work. Do you think its worth it in your opinion to switch it to Manual? Because right about now, I have no transmission, it just died a couple of days ago! So i'm pretty much stuck in a rut now until next summer, because I usually store my camry for the winter. So I basically have now until April 1st to figure something out!!!
Old 11-02-2008, 09:40 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
if you enjoy manual and are willing to put in the time and money then manual ALL THE WAY. the toyota autos are bad when it comes to gearing for the power band for the most part. but i agree with rich, youll learn ALOT more by searching then we can put in one thread.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-02-2008, 11:34 PM   #7 (permalink)
Tom 2000's Avatar
I have a 2000 Camry LE auto like yourself. Unless I get a donor car for a ridiculously low price and have a lot of time, it's not something I would take on.
Personally I would just fix the automatic transmission, then sell the car and buy a Camry with a manual transmission if I really want one.
Take a look at this link. There is a very detailed write up on what it takes to R&R the automatic transmission. It includes cost as well.
http://www.pbase.com/kocho/camry
Tom
2003 Corolla Luxel
Old 11-03-2008, 01:11 AM   #8 (permalink)
00' Camry LE
Karman's Avatar
Ya i really do want to do ... and i've searched for countless of hours but I can't seem to find anyone who's already done this. Also...I dont even know where to look to find a manual transmission for my Camry so I could buy it!!!
^^ I would want buy a new camry with a manual transmission, however is that, i've already modded my car to everything that I wanted on it. So i wouldn't want to re-do all the mods all over again!!!! Do you have any ideas on where I can find and buy the manual transmission?
Old 11-03-2008, 04:37 AM   #9 (permalink)
I HAS BOOST!!!
bigbird's Avatar
well i just did a search and found 6 threads in 2 pages with at least some info on just this subject, so i know its here in the umteen thousand threads.
to get one id give ecale3 a pm. hes got a manual tranny and i believe most of the swap parts and is selling it for cheap, not sure how cheap but but its worth asking him.
also pm myfreecamry, he just rescently did the swap too i believe.
R.I.P.
Car Domain:
Old 11-03-2008, 06:15 PM   #10 (permalink)
00' Camry LE
Karman's Avatar
K cool, thanks man, I PM'ed the both of them. And as far as the search, what did you type in? Cause i'm getting nodda in my searches!
Old 11-03-2008, 10:27 PM   #11 (permalink)
PRSRIZD
MyFreeCamry's Avatar
iTrader Score: 6 reviews
View MyFreeCamry's Photo Gallery
Bigbird, appreciate the thought of me. I haven't done the swap yet, awaiting till spring or until I can get a heated garage.
As far as the searching goes, just type in trans swap, 5spd swap and narrow down the search to the gen 3 & 4's.
And don't give up, it took me several months to find the parts and when I finally did, I bought everything that is listed above and some more for $150!!!
1990 Yota truck - 2wd 4spd, 22r. Lowered 5", 17" Ford Escape rims, flat green paint.
1992 Camry - Going back to stock. GONE View my parts for sale - http://www.toyotanation.com/forum/sh...47#post2908847
MyFreeCamry is offline   Reply With Quote
Old 11-05-2008, 06:46 PM   #12 (permalink)
00' Camry LE
Karman's Avatar
Hey man,
Outta curiosity which manual transmission would i have to get for my car? would it have to from a lexus or a different car like that? Cause I can't seem to find ANY manual transmission's for sale for a 2000 Camry on eBay or any other site.....or even any garage's near my house (i live in Montreal - Canada)!!!!!
Old 11-05-2008, 09:23 PM   #13 (permalink)
Tom 2000's Avatar
1997-2001 Camry 4-cyl
1999-2001 Solara 4-cyl
Tom
2003 Corolla Luxel
