Is the 1996 V6 Camry engine interference? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2008, 08:37 AM   #1 (permalink)
View donbryce's Photo Gallery
Canada Is the 1996 V6 Camry engine interference?
Hi. Newbie here, as I haven't actually bought the 1996 Camry yet, that will be tonight, I hope. My question (and the search isn't working here):
Is the V6 an interference engine? I want to know if the valves will hit the pistons if the timing belt breaks.
Edit: OK, I did a google and found the Gates timing belt pdf. It would appear that it's a non-interference engine.
donbryce is offline   Reply With Quote
Old 10-29-2008, 10:39 AM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $907727
iTrader Score: 59 reviews
..........and google is correct!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 10-29-2008, 11:19 AM   #3 (permalink)
View llcoolpass's Photo Gallery
it's true, but the valves can still get damaged by the pistons if the timing belt breaks. it's not worth taking a chance [I wouldn't go over 120K on a timing belt even if it was never even near oil leaks and such] as you approach greater and greater odds of failure. They should last at least a solid 100,000 miles on these engines.
yeah i know some people are scratching their heads and saying, "valves Cant make disasteroud contact if the engine is non interference." From the factory, you're right. IT would be very odd for that to happen and the chances are rediculously remote. But, with time and abuse, carbon builds up on the surfaces of the valves and piston reducing this margin of safety [and it HAS happened before].
1993 Lexus ES 300 [completely stock] -- 5-speed Manual V-6 3VZ-FE -- Curb Weight 3,570 lbs; Mileage 152,000 -- 0-60mph http://www.youtube.com/watch?v=ygwUh1MZRLM
llcoolpass is offline   Reply With Quote
