if all you need to do is to change spark plug on v6 rear bank, unless your rear valve cover gasket is leaking, you don't need to remove intake plenum manifold, what you need are multiple 3/8" extension in difference sizes, like 3", 6", 8", save a lot of time and metal gaskets.
i've done a few v6 rear bank spark plugs from top of the intake plenum manifold with any problem, a 30 minutes to 45 minutes job.
to remove the intake plenum manifold, u will need a metric #10 hex bit, and an extension bar, make sure the bit goes all the way, other wise, you may strip or round the bolt.
