thermostat location 5sfe toyota camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2008, 06:27 PM   #1 (permalink)
klex's Avatar
View klex's Photo Gallery
4th Generation thermostat location 5sfe toyota camry
Hey, does anyone know where the thermostat is located on a 99 4cyl camry? The car runs too cold and I can not find the thermostat. Any help would be appreciated. Thanks
klex is offline   Reply With Quote
Old 10-31-2008, 06:44 PM   #2 (permalink)
View BigDog4All's Photo Gallery
REMOVAL
HINT:
Removal of the thermostat would have an adverse effect, causing
a lowering of cooling efficiency. Do not remove the thermostat,
even if the engine tends to overheat.
1. DRAIN ENGINE COOLANT
2. w/ Oil Cooler:
REMOVE OIL FILTER
3. REMOVE WATER INLET AND THERMOSTAT
(a) Remove the 2 nuts, and disconnect the water inlet from
the water pump cover.
(b) Remove the thermostat.
(c) Remove the gasket from the thermostat.
BigDog4All is offline   Reply With Quote
Old 10-31-2008, 08:28 PM   #3 (permalink)
klex's Avatar
4th Generation
Alright, I am a noob, where exactly is the thermostat located? I have no idea where to look except around the water pump. How do I drain the coolant? Thanks for your patience...
Old 10-31-2008, 08:55 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Follow the lower radiator hose to the engine and you'll see the plastic thermostat housing. Remove that and the thermostat is inside.
2007 Camry 2.4L 5M
Old 10-31-2008, 09:23 PM   #5 (permalink)
klex's Avatar
4th Generation
Ok, i'll check it out tomorrow and let you know. Thanks
Old 10-31-2008, 09:49 PM   #6 (permalink)
Removing the oil filter makes getting to the thermostat easier but puts you at risk of getting water in there.
2007 Camry 2.4L 5M
Old 10-31-2008, 11:08 PM   #7 (permalink)
View djb2's Photo Gallery
The thermostat housing is much more obvious than you are expecting. It's up front, somewhat on the passenger side of the engine. Open the hood, and look a little to your left, around the alternator and A/C.
The outlet is held in place by just two nuts. But before you start, plan and gather the tools you'll need to remove both. The nuts are easy to see, but access is blocked by brackets and hoses. You'll probably have to alternate between a socket and wrench.
A new thermostat should cost between $10 and $20.
djb2 is offline   Reply With Quote
Old 11-01-2008, 04:27 PM   #8 (permalink)
klex's Avatar
4th Generation
Ok I bought the thermostat and gasket for $15 and am going to install it on Tuesday when my brother is off of work. I didn't buy coolant I don't think I need any more the reservoir is about a quarter inch above the full line. Do you think I need to buy more coolant? Thanks for all the detailed replies that is greatly appreciated!!
Old 11-01-2008, 05:25 PM   #9 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Get a jug of Toyota red and a jug of distilled water. Don't add just water. Premix is an option if you do not want to bother.
You have mild winters in Coral springs right? So mix coolant and water to your lowest expected freeze point. You need the coolant to lubricate the water pump.
The amount of coolant you will lose is quite a bit. Expect all from the cylinder head, and about 1/3 the rad.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 11-01-2008, 05:40 PM   #10 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
My car runs kinda hot... I just flushed out the whole coolant system, and added green pre-mixed coolant/anitfreeze.
Should I look into a new thermo as well?
Thanks
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 11-01-2008, 11:11 PM   #11 (permalink)
Thanks
What do you mean by "runs kinda hot"? Is it overheating?
2007 Camry 2.4L 5M
Old 11-02-2008, 01:09 AM   #12 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Sorry I should've specified....
I bypassed the TB with my coolant line and my TB and CAI are scalding hot lately, even after a decently short drive.
They used to be cold to the touch!
Thermo has anything to do with this?
ACCIDENT...
Thanks
Old 11-02-2008, 01:15 AM   #13 (permalink)
fnkytrd's Avatar
View fnkytrd's Photo Gallery
klex... I've had bad experiences with using aftermarket thermostats. You may end up changing it out again if you don't use a toyota one. I wouldn't skimp on a part that cools your engine.
fnkytrd is offline   Reply With Quote
Old 11-02-2008, 11:07 AM   #14 (permalink)
klex's Avatar
4th Generation
Ok, i'll call Al Hendrickson Toyota on Monday and return the thermostat I got from advance auto parts. I didn't think of that as much...
Old 11-03-2008, 12:39 PM   #15 (permalink)
klex's Avatar
4th Generation
Ok I went to the dealership and got a thermo and gasket for $32 and change, about twice as much as the advance auto parts brand but it will pay for itself when the car is still kicking when the aftermarket one would have died(maybe a year or two from now). So i'm not bothered by spending twice as much. I'll install it tuesday or wednesday and i'll get back to you guys. Thanks!!
