Hey guys,
My 93 LE 4 cyl auto has an issue with the gear indicator lights by the speedometer. Sometimes they will light up and sometimes they won't. Most of the time, D N R will not light up, but P 1 2 will. If I jiggle the shifter, it will flicker. I did a little research and since I replaced the dash bulbs, I think it is the neutral safety switch (also known as Park/Neutral position switch).
Online, I am finding new replacements for around $200. Not ideal. One thing that is confusing me is
this (scroll down to where it says "fits vehicles"). How can the same switch work for vehicles with different pinout/connectors ('94 and later models use pins 2-10, '92-'93 use pins 1-9 and in a different configuration)?
I found
this ebay auction for a v6 '92 part for $50. The Haynes manual shows no distinction between 4cyl and v6 in terms of the neutral position switch pinout, so that is a plus. Also, from the manual it looks like the pinout/connector is the same between '92 and '93. But the 'housing' looks physically different. Will I be able to mount this properly in my '93? Is this an easy thing to replace?
Any other suggestions are welcome (maybe I can just pop open the neutral safety switch, clean off some electrical contact surfaces and be good as new!). Thanks
